Samsung Galaxy Note 20 | Note 20 Ultra
Zinc-Oxide
Ya I bought a new set from Qoo10 I can't stand normal screen protector.
Tried both hydrogel and spigen neoflex all cmi. Super rubbery
The original screen protector is the best out there not comparing WS. Its free and oleophobic coating is good.
U replace a new Whitestone?
tclong
Will Samsung Galaxy Note 20 colour variant be available in SG?
It’s still early days, but Samsung does have a habit of adding new colours to its phones months after their release — so fingers crossed, yeah? :D
frizee
Lol kinda miss my Note 20 Ultra SD now! :D
Street price still in the ~$1,400 ish range :(
daylight
still thinking whether to change to note 20 ultra from note 9.yesteday took photos then the display go haywire n turn very hot. but okay after a while.
samsungXP
just want to ask do we need change to 5G sim to get 5G network ? currently using 4G sim in my note 10+
ahkok
Note 20 Ultra voted best smartphone 2021 by consumerreports beating S21U! The actual consumerreports article is hidden behind a paywall, but here's a video:
dodongdodong
best smartphone is the one that meets your need and budget
megascwk
Actually what will be your usage scenarios.
If you are using it for gaming or using it to edit and export long video clip to YouTube then yes SD better. Or any use case that uses intensive cpu or gpu.
But if you are only using it for social media and content consumption or just social media taking photo and video, there is not much performance difference. Though so may say battery slightly lesser (after recent patch) comparing to SD but that’s is only slight not significant.
But that been said N20U (both SD / Enoxy) version battery life not that great.
As for photos taken some felt that SD photos better but YouTube had shown there is no noticeable difference in blind test plus if you are sharing over social media the compression algorithm totally mask whatever image advantage (if there is any).
So don’t buy base in SoC decision buy it base on use case.
Lastly overseas export set forth N20 seems to have country code / area code issue which requires workaround but no such issue with local set.
5G (though no use now) also is ok with local set and spotty with export set.
i am using korea note20u and doesnt seem to have
Can someone please help? :(
A friend of mine got a Note 20 5G Korean Snapdragon set after I recommended her "the reason why" SD vs Exynos but but she said only the numbers are showing and i feel its on me since i recommended. Names are NOT showing despite being saved and I know in this forum there is mentioned but not for korean phone.
I posted here in the hope that you guys who are more expert can advise on what to do.
The numbers simply do not show . Hope you guys can advise. Did search but can't find this issue to the Korea set.
Thank You.
how about volte? is the set able to receive volte and without disappearing after a period of use?
megascwk
do you have any idea on volte issues? i am using korea note20u with m1 telco. my volte keeps getting disabled after a period of use and triggered on after i restart my phone everytime
megascwk
M1 , VoLte work flawlessly since Day 1
Sent from Note 20 Ultra Snapdragon™ using GAGT
Hi, are you using HK or korea SD n20u set? i am using korea SD n20u set currently and can't get volte. Need some suggestions on how i can enable it
megascwk
Thank You.
could you help me check if her korean SD n20u set has working volte as well? I am using M1 telco and my volte kept getting disabled after a period of use and can only be triggered back after phone restart
Teo Ming Ern
Can you guess correctly ?
P40PRO+ vs Note 20 Ultra
The Note20 Ultra exihbits less blooming in the reds and is noticeably cooler hence the pictures look more balanced... but must check if the P40 Pro+ was in the right mode or not... I'm presuming both are in fully automatic mode...
