Huawei AX3 Pro - Anyone bought and tried?
Ic... but this Huawei so much stable.
the only downside is the speed,
1 router = 800Mbps on my Samsung Galaxy tab S7+
2 router mesh = 120Mbps on my Samsung Galaxy tab S7+, on Desktop is 380Mbps
wonder why WiFi speed drop so much?
Because you use wireless backhaul. Part of the bandwidth will be used for the backhaul (communication between the main router and mesh node). This is the common problem with dual band mesh system.
Connect the two router using Ethernet to use Ethernet backhaul and you will see big differences.
Triband mesh systems are more expensive because they have the extra band to serve as dedicated backhaul. Still Ethernet backhaul is the best.
adriankmf
ic, thanks for the info.
understand now....
cheers.
SandMan
I've been happily using ax3pro for a long time and it worked flawlessly in my old place without any cooling needed.
Now in my new place, it will drop internet about once a day (red light on router), requiring a restart. Since it is now in a room hit by afternn sun I assumed it was overheating so I ordered a base cooling fan. With the base cooling fan on max and room fan turned on, it will still randomly drop internet even on a cloudy day. It also dropped only once at night, but never when aircon is on.
I've just switched to my old trusty dlink 868 and it's been working flawlessly for more than a week, so problem is not with Starhub or any cables used.
Any ideas appreciated.
UPDATE:
Just to share with anyone else having serious overheat problems. I tied a thermal pad with heatsink to bottom of my ax3pro using cable ties and it solved the problem. I also stand the ax3pro on its side so that heat wont get trapped under it. Looks awful but works well.
Can get heatsink + thermal pad here (128x200mm):
https://detail.tmall.com/item.htm?i...e8digf2xN&_u=k1u2t19r0a6b&skuId=4757353267209
HelIoo
Will it work with singtel router as a repeater? Trying to add additional router in a room as a repeater as i dont have hard wired structured cabling.
ont -> singtel router
limpingsim98
Once received, during setup please help to confirmed whether this router support Vlan or not. Thanks
The global version has it. Has play with it at Court Mega Huawei counter. Is actually the AX3 Pro version. If remember correctly price is $98. If purchase with Huawei tablet then price is $68.
Global version supports SingTel VLAN. It is called AX3 Quad Core version.
Some reports say it is different than AX3 Pro China version in terms of the Front-end Modules or FEM ( RF Amplifier etc) and therefore has lower TX power than the China version.
limpingsim98
. The same hardware. Just FW control to comply.
JuXn5566
No, the tear down shown the international version doesn't include 2.4Ghz amplifier thus it's very weak in that area. Btw, international version also didn't receive any firmware update since Nov last year.
cscs3
Just wondering where you get the info. I was trying to search for this but there is no conclusive comparison (say with tear-down comparison).
Someone mention it in LowYatt forum in Malaysia. They had it for sometime already and they confirm is the same hardware. As locally, we do not carry non pro version.
limpingsim98
I think is to comply with local regulations.
For FW, this is kind of expected. If you happen to use phone like Xiaomi etc. Do not expect Global version to get update as frequently as China one.
JuXn5566
Don't think so. The 2.4GHz range is much weaker than my previous router and barely usable. My previous router is Archer C8 for global market. I expect them to reduce the wifi power but not discreetly remove 2.4GHz amplifier totally.
For FW, yes I expect less frequent update but not no update at all. Currently more than 6 months with no new update so seem like they not planning to update it all together.
limpingsim98
Actually, I believe the amplifier is there just the firmware cap of transmission power to local requirement.
For FW, I don't expect much for these devices. If you happen to use Linksys, they are as bad.
Huawei AX3 Pro tear down: both 2.4GHz and 5GHz band have amplifiers.
https://root-nation.com/en/other-en/net-en/en-huawei-wifi-ax3-review/
Tear down picture for AX3 Quad Core Global version (WS7200-30), it is not very clear. I am searching for an article with proper picture and amplifier IC name. But from what I read in the thread, indeed the HW components used should be the same as the China version AX3 Pro (WS7200-20), which means there are external RF front end amplifiers for both 2.4GHz and 5GHz bands.
https://forum.openwrt.org/t/support-for-huawei-ax3-pro/66551/91
