- Sep 16, 2018
Ic... but this Huawei so much stable.
the only downside is the speed,
1 router = 800Mbps on my Samsung Galaxy tab S7+
2 router mesh = 120Mbps on my Samsung Galaxy tab S7+, on Desktop is 380Mbps
wonder why WiFi speed drop so much?
Because you use wireless backhaul. Part of the bandwidth will be used for the backhaul (communication between the main router and mesh node). This is the common problem with dual band mesh system.
Connect the two router using Ethernet to use Ethernet backhaul and you will see big differences.
Triband mesh systems are more expensive because they have the extra band to serve as dedicated backhaul. Still Ethernet backhaul is the best.
