eting72
- Jun 10, 2006
oh...I don't know about that. most likely not as it wasn't stated.I just ask cos I saw Lazada and Shopee includes free backpack
ONT or ONR ?Just got the Asus RT-AX86U to replace Singtel default router. However when I tested the wi-fi speed, I don't see any significant improvement in the speed, in fact it seems to be little worst. It is still around 200 - 270Mbps for download and around 210Mbps for upload on a wi-fi 6 device.
Any idea what went wrong?
ONT or ONR ?
If doing speedtest.net, don't test to Singtel server, it maxes out around 200+. Choose Viewqwest server. Try flashing to Merlin firmware, then check your wifi settings for 5ghz in the router under professional tab is mu mimo + ofdma.Just got the Asus RT-AX86U to replace Singtel default router. However when I tested the wi-fi speed, I don't see any significant improvement in the speed, in fact it seems to be little worst. It is still around 200 - 270Mbps for download and around 210Mbps for upload on a wi-fi 6 device.
Thanks for the advice! I turn on WiFi Agile Multiband and mimo + ofdma. Then choose ViewQuest server for testing. Able to get around 500 to 600+Mbps now.If doing speedtest.net, don't test to Singtel server, it maxes out around 200+. Choose Viewqwest server. Try flashing to Merlin firmware, then check your wifi settings for 5ghz in the router under professional tab is mu mimo + ofdma.
My work laptop has the Intel Wireless AC-9560 which supports 2*2 AC 160MHz.
Speedtest result is amazing with RT-AX82U. SingTel 1Gbps plan, Viewquest SpeedTest server.
Yes SingTel Speedtest server always reports lower speed (usually less than 400Mbps) than Viewquest (much faster) if testing wireless.
But for AX routers, I find Asus stock FW is good enough, no need to use Merlin as of now.
Oh wow. Yah, I'm still using Asus stock FW. Even though I'm getting around 500 to 600+Mbps for download, I'm still getting around 200+ish mbps for upload. Is this normal? I'm testing it on my iPhone 12 Pro speedtest app.Nice.
Viewquest server is good.
So I configure the router to support 2 Singtel TV set top box. But I don't know if it some psychological effect or my imagination, the picture quality looks slightly deteriorated as compared to using Singtel original router. Am I thinking too much?
I am getting this speed on my Andriod hp. Using M1 500mbps fibre.
Xiaomi note 8.That speed (307Mbps download and 325Mbps upload) is actually normal speed if you use a 2*2 AC mobile phone (max theoretical speed is 866 Mbps) although a bit on the lower side (good one should get 400Mbps+ on a 500Mbps plan). What is your Android mobile?
Still it does not really matter whether you get 300Mbps or 400Mbps in daily use cases for a mobile phone.
Xiaomi note 8.
Will wifi6 router boost up speed? Am thinking hard to get a wifi6 router once I change my pc system
