Asus GT-AX11000/Pro, RT-AX89X, , GT-AX6000, RT-AX88U Pro, RT-AX86U/Pro, RT-AX86S, TUF-AX6000, RT-AX82U (V1/V2), TUF-AX5400, RT-AX5400 and TUF-AX4200
SongManKranji
High Honorary Member
I will not be surprised if Redmi Note 8 only support 1*1 Wifi AC (max speed 433Mbps). And in that case what you get is pretty good.
I thought you were using RT-AX86U or RT-AX82U. So you are not using a wifi 6 router, which router are you using? And yes if you are using a PC with Wifi 6, then WiFi 6 router makes sense.
am still using AC68U. 1 at in laws place and 1 at my own place.
I should get 1 mobo that's wifi6 than change AX82U?
Life is v short. Ai song song nia kao tuas ah.
You need both a wifi 6 device and a wifi 6 router to enjoy WiFi 6 speed.
If your PC is not too old, you can just buy a PCIE Wifi 6 card which is pretty cheap. New generation of laptop will also support WiFi 6.
And you can get the RT-AX82U to replace the RT-AC68U as the main router. Your RT-AC68U can be used as an AImesh node in the room.
eting72
which PCIE Wifi 6 card would u recommend?
Intel AX200 based.
Higher quality: Asus PCIE-AX3000 /AX58BT or TP-Link Archer TX3000E.
Low cost and good enough: Comfast brand
I am using cheap Comfast brand for my laptop and it works fine. The PCIE version should be good for desktop.
https://m.tb.cn/h.4EGsGZq?sm=debe96 COMFAST AX210PRO增强电竞游戏3000M千兆双频5G英特尔AX200无线网卡台式机电脑蓝牙内置PCIE独立WIFI6接收器
TheCoolDude89
The Asus AX86U is a very good router. After buying from courts and setting it up, my wifi connection is more stable and better.
SongManKranji
how about Ax 56U is it gd Enuf or settle for ax 82U
Life jin short. Ai song song kao tuas
It will depend on your requirement and budget. I will not go for RT-AX56U, minimum RT-AX58U.
RT-AX82U is more future proof, rated AX5400 (4 * 4 160MHz support in the 5GHz band, up to 4800Mbps in the 5GHz band).
RT-AX58U is rated AX3000 (2 * 2 160MHz support in the 5GHz band, up to 2400Mbps in the 5GHz band).
RT-AX56U is low end AX1800 rated (2 * 2 80MHz support in the 5GHz band, up to 1200Mbps in the 5GHz band).
RT-AX55 is low end AX1800 rated (2 * 2 80MHz support in the 5GHz band, up to 1200Mbps in the 5GHz band).
SongManKranji
Ok tks for the table comparison, like u say more future proof (y)
SongManKranji
Hi I just change my motherboard and realise the properties showing wifi4. Is there something wrong.
eting72
the ax86u speed seems similar to my previous ac86u...am i doing something wrong? but my equipment not wifi 6...any advice?
ordered an ax pcie adapter
