SongManKranji
High Honorary Member
- Dec 11, 2001
am still using AC68U. 1 at in laws place and 1 at my own place.I will not be surprised if Redmi Note 8 only support 1*1 Wifi AC (max speed 433Mbps). And in that case what you get is pretty good.
I thought you were using RT-AX86U or RT-AX82U. So you are not using a wifi 6 router, which router are you using? And yes if you are using a PC with Wifi 6, then WiFi 6 router makes sense.
I should get 1 mobo that's wifi6 than change AX82U?
Life is v short. Ai song song nia kao tuas ah.
