Now really no response. Something happen again after some update... Before that the gateway scanning is fine.
Mine was the transparent case with thicker bump on 4 corners. From Mobile lite.What case is everyone using? There seem to be limited selection of cases even at amazon.co.jp...
I liked the Spigen Liquid Air armor for my Pixel and iPhone but I can't find an equivalent for Xperia 1 II...
Was tempting at first...but most probably not upgrading.I still on the fence on weather to upgrade to 1 iii..
yeah.. i think high chance skip this one. get mk iv insteadIf money is an issue then it is not very worthy, incremental upgrades every year is only for those with plenty of spare cash.
Xperia 1 II do not have 120hz.Hi all, may i know is Xperia 2 able to use 120hz now? Any if they have, do you all enable it without any issue?
I am currently using Samsung Note 10+, feel like jumping back to Sony now.
There's no xperia 2 only xperia 1II. This generation does not have 120Hz refresh rate display , only the 5II and 1III has it.Hi all, may i know is Xperia 2 able to use 120hz now? Any if they have, do you all enable it without any issue?
I see, thanks alot bro..Xperia 1 II do not have 120hz.
You will have to get the Xperia 5 II if you want 120hz, or wait for the upcoming Xperia 1 III or 5 III.
Sorry, i type wrongly. Should be Xperia 1 ii...There's no xperia 2 only xperia 1II. This generation does not have 120Hz refresh rate display , only the 5II and 1III has it.
Naming system
Pro series - Really for professional usage unless you filthy rich go get one and sponsor me too ~
1 series - the premium flagship
5 series - the flagship (with smaller display)
10 series - the mid end.
I, II, III, IV , - the generation.
.5II highly likely won't shut down. Its using snapdragon 865 which is manufactured by TSMC and not like the snapdragon 888 which is manufactured by Samsung (disappointing heater ) .I see, thanks alot bro..
Sorry, i type wrongly. Should be Xperia 1 ii....
Just wondering, if Xperia 5 ii 120hz is enable. Will it run into any overheating issue and shut down?
Hmmm..5II highly likely won't shut down. Its using snapdragon 865 which is manufactured by TSMC and not like the snapdragon 888 which is manufactured by Samsung (disappointing heater ) .
. Samsung Snapdragon 888 more advance 5nm chip is running more hotter than TSMC Snapdragon 865 older 7nm chip?...
