Sony xperia 1 II
omelet
What case is everyone using? There seem to be limited selection of cases even at amazon.co.jp...
I liked the Spigen Liquid Air armor for my Pixel and iPhone but I can't find an equivalent for Xperia 1 II...
Toader
Mine was the transparent case with thicker bump on 4 corners. From Mobile lite.
chunxi
the touch gateway only work for me once and never again.
restart app, bluetooth, phone no help.
the pda gateway 1m away can detect me.
GeSteSoh
New update downloading.... wonder what the performance/feature updates are?
Only wish the normal camera app would update to take better AI HDR+ photos :D
Hi all, may i know is Xperia 1 II able to use 120hz now? Any if they have, do you all enable it without any issue?
I am currently using Samsung Note 10+, feel like jumping back to Sony now.
Edited: Xperia 1 II.
omelet
Hi all, may i know is Xperia 2 able to use 120hz now? Any if they have, do you all enable it without any issue?
Xperia 1 II do not have 120hz.
You will have to get the Xperia 5 II if you want 120hz, or wait for the upcoming Xperia 1 III or 5 III.
Toader
There's no xperia 2 only xperia 1II. This generation does not have 120Hz refresh rate display , only the 5II and 1III has it.
Naming system
Pro series - Really for professional usage unless you filthy rich go get one and sponsor me too ~
1 series - the premium flagship
5 series - the flagship (with smaller display)
10 series - the mid end.
I, II, III, IV , - the generation.
I see, thanks alot bro..:)
Naming system
Sorry, i type wrongly. Should be Xperia 1 ii...=:p.
Just wondering, if Xperia 5 ii 120hz is enable. Will it run into any overheating issue and shut down?
Toader
5II highly likely won't shut down. Its using snapdragon 865 which is manufactured by TSMC and not like the snapdragon 888 which is manufactured by Samsung (disappointing heater ) .
Hmmm.. :s11:. Samsung Snapdragon 888 more advance 5nm chip is running more hotter than TSMC Snapdragon 865 older 7nm chip?... :s31:
