watzup_ken
- Nov 21, 2003
Actually after you asked, I started checking out the temps. I feel the temps did drop, but again I wasn't able to test the same game to determine this. The best way I could kind of gauge how effective the mod went was by looking at a game that makes the GPU draw about the same amount of power. In Metro Exodus EE, it was stressing the GPU more and based on readings from Afterburner, it was pulling 10% more power on average, than when I am playing Control. I am skeptical if the T30 will solve the fan noise issue, but I think it should improve the cooling of the GPU by bringing the fan closer to the heatsink. Let's see when the T30 arrives and I have time to install it.Thanks for sharing. I think that's actually not too bad. Out of curiosity I went to try out 3dmark with clocks set to 1975/900, and peaked at about 72 degrees on my regular fan curve. But I did reapply paste as well as changed pads, which helps.
The old GTs has a hum at certain RPMs iirc, maybe that could explain the whine. Definitely the gap does have an impact, which is why some modders who use 120mm fans 3d printed a shroud to redirect the airflow into the heatsink.
Thanks for starting this thread. I've been waiting for the noctua chromax a12s forever, now I'm looking forward to the T30s![]()
