Pocophone F3
60 and 120 both looks same to me, maybe 120hz can scroll faster. Even ip13promax i try also cannot see any difference between 60 and 120hz.
Go watch YouTube. Got one showing only 1 out of 5 people can tell the difference when testing the ip13 pro max.
Any issues with trace together and nfc payment ah
twosix
No issues. I tried TT scanning with BT a few times. No issues but i prefer to scan QR code. Can use google pay to pay for purchases so no issues with nfc too.
Although this phone comes with sd870, playing pokemon unite will start to lag around 30min of gameplay, and it is not a really heavy intensive type of game. I play same game on my ip11 for an hour with zero lag. Haha....
KeYoKe
No wor. Iphone 60hz animation is smoothest among all the 60hz phone. 60hz on android is alot worst than iphone 60hz.
I have used ip13 pro max, and the 120hz is way less obvious than android. Not a good comparison anyways
twosix
anyway, ip11 and any android @ 60hz all same to me. ip13promax and android @ 120hz also all same to me. as i've always said, i'm very lucky to be able to not tell the difference. imagine if one can see the difference, using the phone at 120hz, then watch tv, pc monitor, laptop or ipad at 60hz. won't it be weird? haha...
KeYoKe
Umm that's not my point. My point is comparing iphone 60hz and 120hz vs android 60hz and 120hz is different due to the iOS animation implementation is the best around, so the difference aint that big :s22:
You cant see the difference is good for u. But i can tell the difference definitely. You might not realise immediately. But try using 120hz for a week, and switch back to 60hz, u will definitely notice it.
And the distance between your eyes and the phone, vs tv is different too, so obviously it wont be that visible to u.
However, on pc monitor, labtop i also notice the difference
PattyTheChuggyTrain
For me I have a lot of problem angling and re-angling the phone to make the TT scanning device pick up my F3.
Zenosyne
does downloading gcam help the camera? such as the ultra wide night mode ? read that many downloaded gcam and it helps?
PattyTheChuggyTrain
GCam doesn't auto apply beautifying filters on faces. The stock camera will do it without being able to disable it.
But GCam isn't good to use though, a bit iffy.
