 Watch Series 7
ahyoo2002
Zero scratch on Aluminium after using for 2 years plus including exercise (main reason for AW).
tohchr
Anyone notice on this new watch os or watch 7, even disconnected from Bluetooth but both iPhone and watch connected to same wifi network, the watch battery will still show on the battery widgets on the iPhone.
Cronares
Thx for the info
Currently buying the graphite @ comcentre
Does your watch have the seal when you bought it? I came back home and realise there’s no seal Sia WTF? But all the items is intact and seems like the Apple Watch wasn’t activated before either
Jirachi
Better to check with Singtel.
tohchr
Should have seal on both ends, just similar to iPhone 13, a tear off sticker.
Snoweagle
I just checked mine, don’t have leh.
tohchr
Strange!! I tested mine, watch is link to iPhone even though bluetooth turn off. Both wifi must be connected to same network, if wifi also turn off, then the watch totally disconnected from iPhone.
Another test is, I connect both iPhone and watch using only wifi, when I turn on Focus to sleep on the watch, iPhone also immediately change to focus sleep mode.
Snoweagle
I don’t use focus at all, but once my watch is disconnected from BT, it no longer appears in the phone’s battery widget, even if wifi is turned on from the watch.
Op_Valkyrie
This is correct all the while, got different now only meh?
10DeeQ
Mine is sealed , but the person at the comcentre opene it in front of me to check the watch.
the outer box not sealed , but inside got 2 boxes , 1 is for the watch (sealed with stickers like iphone 13) and 1 more is the milanese loop box (sealed with stickers too)
saggice
u must be a very careful person.
I belong to the rough group lol … sometimes it’s also kenna knocked / brushed by other ppl when walking or running
