Apple announces new 14 and 16-inch MacBook Pro, powered by new M1 Pro and M1 Max chips
Glariel
The wait is over. Apple has finally unveiled the highly anticipated 14 and 16-inch MacBook Pro and new Apple Silicon chips.
The new MacBook Pros are powered by Apple’s newest M1 Pro and M1 Max chips. Essentially, these are souped-up versions of the M1 chip that made its debut last year.
(Image source: Apple)
They are built on the same 5nm process. M1 Pro has a 10-core CPU with 8 performance cores and 2 efficiency cores. It also has a 16-core GPU. Memory bandwidth is a staggering 200GB/s and it can be configured with up to 32GB of memory. Apple says M1 Pro will deliver 70% faster CPU performance and twice the GPU performance of M1.
And then there’s the M1 Max. This has the same 10-core CPU but it has a GPU that goes up to 32 cores. It has a whopping 400GB/s of memory bandwidth and can be configured with up to 64GB of memory. This means M1 Max has four times the GPU performance of M1. For pros, Apple says the M1 Max can edit up to 30 streams of 4K ProRes or up to 7 streams of 8K ProRes videos simultaneously.
Apple says M1 Max can deliver performance close to a high-end laptop while consuming 100W less power. (Image source: Apple)
These new chips will be going into the new 14 and 16-inch MacBook Pro. To start, their chassis is not quite squared off as we had expected. There’s a gentle curve to the base. The displays are also a little larger than advertised: 14.2 and 16.2 inches. Resolutions are 3456 x 2234 pixels for the 16-inch MacBook Pro and 3024 x 1964 pixels for the 14-inch MacBook Pro.
The 14 and 16-inch MacBook Pros have Liquid Retina XDR mini-LED displays. (Image source: Apple)
These new MacBook Pros have Liquid Retina XDR displays, which means they are mini-LED displays like the 12.9-inch iPad Pro. Thousands of little LEDs in the display help better control lighting for more precise brightness and contrast. The results are 1,000 nits of sustained brightness; 1,600 nits of peak brightness; 1,000,000:1 contrast ratio: and 1 billion colours. They also support ProMotion technology so they can ramp their refresh rates from as low as 10Hz to as high as 120Hz.
You might also notice a notch in the display. That’s for the webcam which now shoots at 1080p – double the resolution. It has a new 4-element lens with a wider aperture and according to Apple delivers two times better low-light performance. I’m sure this will be handy since many of us are still working mostly at home.
Yes, that's an SD card reader and a full-size HDMI port. (Image source: Apple)
Also improved is the connectivity. The old MacBook Pros only had USB-C ports and it seems that Apple has taken the feedback of its users seriously. The new MacBook Pros now come with three USB-C Thunderbolt 4 ports, a full-size HDMI 2.0 port, a headphone jack, an SD card reader (finally!), and a MagSafe 3 connector. And while you can charge using the MagSafe 3 connector, USB-C charging is also supported which means you can reuse your USB-C power adapters.
The keyboard has also been improved. The Magic Keyboard is said to have the feel of mechanical keyboards. More importantly, the dreaded Touch Bar is gone and Apple has given us full-height function keys. The trackpad, thankfully, remains wonderfully expansive. The power button also has Touch ID for quick logins.
The new MacBook Pros have 6 speaker sound speakers that support Spatial Audio. (Image source: Apple)
On the audio side of things, these MacBook Pros have three studio-quality mic arrays that have a 60% lower noise floor and a new six-speaker sound system with two tweeters and four force-cancelling woofers. We have seen this tech before in the M1 iMac. Apple says these woofers go up to half an octave deeper and deliver 80% more bass. The speakers support Spatial audio too and can create an immersive 3D sound stage if you listening to music or watching movies with Dolby Atmos.
Battery life is said to be up to 17 hours of video playback for the 14-inch MacBook Pro and 21 hours of video playback for the 16-inch MacBook Pro.
Pricing and availability​
You can order the new 14 and 16-inch MacBook Pro from the Apple Online Store soon. And there’s no word yet on their exact availability in Singapore.
That’s not a bad thing because pricing is a little confusing and will likely require a little time to consider. These systems are highly configurable and the new M1 Pro and M1 Max come with various GPU configurations.
Prices start at S$2,999 for the 14-inch MacBook Pro with an M1 Pro with 8 CPU cores, 14 GPU cores, 16GB of memory, and 512GB of storage. Prices start at S$3,749 for the 16-inch MacBook with an M1 Pro with 10 CPU cores, 16 GPU cores, 16GB of memory, and 512GB of storage.
If you want the M1 Max, the cheapest 14-inch MacBook Pro with M1 Max is S$4,349 and that comes with 10 CPU cores, 24 GPU cores, 32GB of memory and 512GB of storage. The cheapest 16-inch MacBook Pro with M1 Max is $4,649 and that comes with 10 CPU cores, 24 GPU cores, 32GB of memory, and 512GB of storage.
The cheapest full-fat M1 Max with all 32 GPU cores is S$4,649 for a 14-inch MacBook Pro and S$4,949 for a 16-inch MacBook Pro.
Source: https://www.hardwarezone.com.sg/tec...macbook-pro-m1-pro-and-m1-max-singapore-price
TrueBeliever_jh
Anyone planning to get M1 Max~?
Base 14" with Tier 1 M1 Max: 4,349 SGD
Base 16" with Tier 1 M1 Max: 4,649 SGD
Note that you can only configure to at least 32GB RAM if you going for M1 Max.
And 64GB RAM is only available for M1 Max.
arvinsim
Do not that you don't have to go all the way to 32-core GPU for the M1 Max to get 64GB.
One can settle for the 24-core GPU model.
Crimson_FURY
I tried asking chat support, they are giving standard answer of "please check the store from time to time for stock availability". While it literally sells out everywhere else in the world except here. Total BS
yodajedi01
I believe the stock allocation for each countries is low and high in demand.
Crimson_FURY
thats probably true but it doesnt explain why they havent accepted orders from the singapore store specifically
BTW in case there is any confusion, it isnt sold out here, sales just havent started yet for the singapore store. Was told this by apple support staff
wind30
What is the MagSafe port for? I hope it comes with a usbc cable for charging. I share the usbc charger with lots of stuff…. Weird to use a seperate cable for one device charging ….
Glariel
obviously its for charging
szeli
wow u dunno e legendary MagSafe
