BlackWing1977
- Mar 1, 2006
Dunno how to use the oven function on my microwave...Why use air fryer and not oven to bake?
air fry can only cook on top. what about the bottom? need to flip?Yes you can. I've done tat
Dun need lar the air will circulate mar...air fry can only cook on top. what about the bottom? need to flip?
No need to flip. Air fryer has hot air circulating around.air fry can only cook on top. what about the bottom? need to flip?
making cheesepie with banana nao!No need to flip. Air fryer has hot air circulating around.
So long you are not baking delicate cakes or cakes tat need to rise a lot or requires water bath, it can be done by air fryer
I did my burnt cheesecake in air fryer. Was very successful. 170c for 22min (top covered wif alum foil) and then 2-3min at 200c to get the top burntcheesepie, inside not cook.
nao I try at 160@30.
just as I suspect, air fryer cannot do thick cake.
You got use stick to poke inside to check or not?? If still wet.. can add time and continue baking lor.. that is what I did for my cake.. I keep adding more time to continue.. take out then poke to see if it is still wet..cheesepie, inside not cook.
200? wtf u put max temp of cos chao tar rah...200@20 becum like this.
I oso use tis for cleaning only![]()
Is this also a type of baking soda you can use for baking cake?? As I mainly bought it to help clean my wok...![]()
Cakes usually 160 - 180 degrees c, more delicate cakes use 160 ok liao. Usually can check your cake after 15-20 min. If you see that the top is already brown then cover the top with aluminum foil to prevent it from burning. If you want a nice crust on top then remove the foil for the last few minutes of baking can liao. Always check with a wooden skewer; if it comes out clean then ok liao. If not, just add more baking time in increments of 5 min until done.
u also can try mah, its a good opportunity to meet girls alsolooks good, continue trying, baking can be fun and satisfying, though ah gui never do before
paging for @daryl76
oh ya hor i still have, forgotu also can try mah, its a good opportunity to meet girls also
have skills future credits bo? can use now
ehhhhh my class is aunties but other classes i see some younger ladies though.... guess is heng suay, dunno why aunties more interested in muffinsoh ya hor i still have, forgot
but usually go attend one is aunties?
maybe because got free time on handehhhhh my class is aunties but other classes i see some younger ladies though.... guess is heng suay, dunno why aunties more interested in muffins
