What is the best way to increase storage space on my gaming laptop?
a5c3ndant
I need at least 500 Gb more, using mainly for gaming, like store those game with 50 Gb+ or more, and can plug & play the game. if possible I dont want to unscrew and change anything inside. Will the speed be affected much if i connect via USB? Any advice?
testerjp
Store in cloud lor. Not scare of failure but only scare of leak. :o
The cost of maintaining the hard drive probably cost about the same as a cloud subscription. :o
kiyomaro
for non frequent use, can consider portable HDD
for frequent use, best ish just buy HDD , unscrew and screw it in.
chiu only need do it once anyway.
Ideasmiths
Another 911 entitled IT call for help
Of course edmwers know ALL The laptop brands in the world, all the models and wtf is inside.
Ideasmiths
Same for TS, no need unscrew anything, just dip the laptop into a pail of water to wash out all the junk that is taking up space......
a5c3ndant
external HDD need power supply, right?
Most gaming laptops should have support to add on a second storage - add in a new nvme/ssd drive :s
If not, connect an external ssd via thunderbolt
thanks everyone for helping me to start & narrow down my google-ing. think i will use external SSD, but i dont think i have thunderbolt port, i only see like USB 3.1 ? still can use?
got cd rom or dvd rom?
replace it with hdd dock
a5c3ndant
Then read/write speeds will be slower
What's your laptop model? See if it supports adding a SSD internally .. then take it to a competent shop and ask them install a compatible 1TB SSD. Will work out cheaper than external ssd for sure .. and less hassle
how much slower? say for example, BF2042. if load the map takes like 1 minute+ still can lah. i dont mind waiting, just as long as the game can function properly. If lets say load FPS game is longer, then i just install non-FPS (light duty) games on the external HDD and use my main HDD for heavy duty loh
