Pocophone F3
dreamz13
Lazada got CNY flash sale on 15th 00:00. 6/128gb selling at $404 and 8/256gb at $434
frizee
Shopee too!
Hmm actually very strange, seems like only 6/128 is already showing the promo price of $404, I just did a check-out, placed an order at $374. :)
Update: Just realised it (6/128) went down to as low as $366
twosix
Shopee too!
cancel the earlier one and order again?
twinbaby
Hi there,
for the grab pay and tap, is it possible to use it on not samsung related phone or not?
2ndly, anybody has used the NFC feature so far? How was it?
twinbaby
Is there any accessories or back cover that I can buy to put on the Poco F3 phone.
I am currently using a silicon cover.
frizee
Lol can ask, does the F3 itself come with a pre-installed film screen protector? Haven’t order one lol…
Hailgod
yes but its a cheap plastic. no oleophobic coating, sticky on the finger. replace or remove it asap,
cybertech
I find the screen protector actually ok. Just that it not covered full screen with 1 mm gap between the edge.
Any screen protector with full screen coverage of Poco F3? I used Full Cover 3D Hydrogel Film for Huawei Mate 10 and it lasted many years, now finding a similar Hydrogel Film for F3.
yukita
anyone having issue with proximity sensor? when i'm on a call, it will accidentally trigger other things eg, disconnect call, activate aeroplane mode, turn off bluetooth etc, depending what menu your face touches.
any solution or suggestion?
tingsters
it is just a suggestion u may want to try the proximity sensor reset/fix app by tech tool
see if this help?
or what casing are you using bro?
what kind of screen protector ? ,
or you might want to clean the top of the phone where the sensor is ?
