I am also looking at 12700 as a stopgap measure.I'm thinking of pairing the 12700 with the H610 since this is the only 65W CPU with E cores and I don't intend to overclock anything or any GPU. However, I don't see this in the price list. Only the F variant is being sold here. Hope they will bring it in.
12400 non-K running at 5.2 Ghz all core.
Looks like the whole bios "bug" where you could tweak non-K CPUs is back again on this Asus DDR5 Apex and Hero motherboards (0811 bios version). 12400 non-K overclocked via BCLK like Intel OC days before Sandy Bridge.
I expect Intel to force Asus to change this quickly though just like they tried to remove AVX-512.
Wow, thanks.... it is true.https://www.tomshardware.com/news/easy-mod-reduces-alder-lake-cpu-temperatures-5-degrees-celsius
The transition from the LGA1200 socket to the LGA1700 socket saw a 42% increase in pin count, resulting in a more extended socket. Consequently, Alder Lake chips are larger and more rectangular than Rocket Lake, which is smaller and has a more squared shape. The problem falls on the Independent Loading Mechanism (ILM). The ILM still latches to Alder Lake processors at the same pressure points as Rocket Lake. The result is that the mechanism pushes down on the processor in the center, causing it to sit lower than on the edges. It's the reason why Alder Lake's integrated heat spreader (IHS) eventually takes a concave shape after several hours of operation
Asrock Z690 Extreme CPU holder puts a lot of tension on the IHS.
I checked the CPU heat spreader and now it shows a very slight concave (like 0.1mm).
After adding washers, it didn't change the max CPU temps.
Probably will only affect extreme overclocking.
Nope, the pressure need not be alot. Most likely those who had problems is because their CPU PCB already bent too much, and trying to fix the problem with washer will simply not work because the edge of CPU is lifted off the pins.The CPU holder mechanism is indeed stiff even on my Z690 Apex. People that have added washers to some of these extreme boards have had their memory clocks not running stable or properly after that. I think the pressure exists for a reason or clearance for that matter. The one thing that somewhat worked is loosening the torx screws on the socket. But that's like maybe a 3 degrees difference at max though I don't feel the need to try it with my current temps.
I'm like mid to high 60s on my 5.5Ghz OCTVB profile with all cores around 5.1/5.2Ghz. Disabled E-cores. Will probably enable them later but ring bus at 4.7Ghz is quick with 6000C32 1T. Very noticeable difference in games which is all I do anyways.
I'm not saying the pressure needs to be alot or is responsible for the CPU bending. It is definitely stiffer than LGA1151/1200 sockets I've worked with. The main issue is that some of the stock installed board backplates are not levelled correctly or not rigid enough so when the standoffs are screwed in there is unequal pressure on the CPU causing 1 side to lift. This is further worsened if you're using huge aircoolers like the Noctua.Nope, the pressure need not be alot. Most likely those who had problems is because their CPU PCB already bent too much, and trying to fix the problem with washer will simply not work because the edge of CPU is lifted off the pins.
As long as the the CPU fully contacts and press on the pins, it cannot go down any further because the plastic socket walls is preventing the CPU from going deeper into the socket.
He's following up on 2 possible B550 boards that have an external clock gen that *might* support this. I agree nobody is going to run a Z690 with really expensive DDR5 MB just to do this and it might be too buggy for stable daily use.Then again how many people would run a 12400 on an Apex board? The odds are extremely slim.
Even his SP rating at 158 is a bug. Look at the voltages, it shows N/A. This means that the V/F points in the BIOS is not actually loaded properly. Looks like 0811 has not updated the microcode for the non-K variants.
Should be my final tune for this rigpretty sure it is the fastest 12900k in Singapore by virtue that there isn't much competition lol. Hopefully ddr5 prices come down soon and makes this platform more affordable for others to join in and have fun with.
G.Skill Trident Z5 RGB 2x16GB DDR5 6400 @ S$935 on Newegg SG!![]()
I would go for a 12600k + DDR4 board. If you have the budget, go for 12700k + DDR4 board. Feel that 12700k would be better suited for your requirements as well as being abit more future proof with the additional cores.I am coming from a i7-2600kwhat would be a logical upgrade if I want the enthusiast style overclockability and raw multi processing power for scientific and encoding work? Some light gaming on the side like city skylines and strategy games.
I am asking here as the build thread is dead...very sad.
TIA
TIA
