Samsung Galaxy Tab A7 (2020)
martian09
Hi there, I have a problem... My camera app firstly cannot be opened and it says 'cannot connect to camera'. After trying all ways but to no avail, I did a factory reset.... Sianzzz
But after reset, the whole camera app is gone!!! Cannot be found any where in the app tray!!!
Can someone help me pls!!
Thks!!!!!
tankee531
Thks!!!!!
have you check whether your camera are working ?
open your phone app, click *#0*# to open the test menu and test each camera.
martian09
I used to do zoom calls with the tablet then now suddenly the app is gone.... Both back and front cams
Teo Ming Ern
Try reset again? Did you call Samsung and ask for help? Under warranty they can flash back the ROM for you and check the cameras...
Crimsom
Tab S6 lite vs Tab A7, which one more worth?
both seems very similar with s6 lite coming with s pen and more ram.
But price like quite big gap? S6 lite $400+, A7 $200+?
Teo Ming Ern
Depends on what you need.... do you need the pen? Otherwise the A7 seems better value...
kelvinti
Tab A7 (2020) folks,
Bye bye! :giggle:
I have jumped ship to the awesome new Xiaomi Pad 5 Global Version already after being with the Tab A7 for a long 10 months! :whistle:
See you all there! ;)
Cheers! :coffee::coffee:
Extremme
For this budget and specs, is it still worth buying? My daughter is using Mipad 4 now but its cracking up and it cant play Genshin Impact. Her usual usage are YT, Tiktok, some light drawing and playing games like Genshin Impact
magixz
I have mipad 4 and Tab a7, Mipad 4 (not plus) is lighter and more handy as its smaller. battery life ok as i replaced Mipad 4 battery. Tab A7 seems picky with cable for charging. I need to use a QC3 cable. Previously i used Huawei 5A cable cannot work.
Extremme
But Mipad 4 , battery is already having issues and no more updates hence I thought of just replacing with A7 2020. At least most games can be easily downloaded
Remless
Just for your consideration. I upgraded from mi pad 4 last year also.
From mi pad 4 to iplay40 to lenovo p11 pro to lenovo pad pro 2021.
Cost:
Iplay40 = $229
Lenovo p11 pro = $285
Lenovo p11 pro 2021= $465
The upgrade from mi pad 4 to iplay40 brings a significant performance enhancement.
The upgrade from iplay40 to lenovo p11 pro brings a slight performance enhancement, but significant quality upgrade as it has much better build quality and speakers.
The upgrade from p11 pro to p11 pro 2021 brings significant performance and graphic enhancement, as well as even better screen quality and lighter weight.
I also play genshin impact. The improvement in graphic quality is the most significant when I upgrade from p11 pro to p11 pro 2021. The GPU in snapdragon 800 series is simply too good compared to the lower and middle range chipsets. If your budget allows, I will recommend mi pad 5 or the lenovo pad pro 2021.
I never consider the Samsung A7 because it's as good as no upgrade, and for that price, it's simply not worth it. It's performance is not better than mi pad 4 (kinda worse in fact as it's more optimized for battery life, not performance). U still cannot play genshin impact with it.
https://nanoreview.net/en/soc-compare/qualcomm-snapdragon-662-vs-qualcomm-snapdragon-660
Also do note that snapdragon 662 on the A7 do not support higher than 1080p video, which is actually a downgrade from mi pad 4, which can handle 1440p videos.
Extremme
Lenovo p11 pro 2021= $465 seems quite ok for my budget too. Thks alot..will consider
Remless
Oops. Correction. Its more known as the lenovo pad pro 2021.
Your daughter will love u for this. It also support active stylus so she will enjoy drawing on it also.
