Wa Lau..my TV suddenly turn blank..
paul02
Was watching a movie then suddenly the screen slowly fading away till black screen and can still see backlight.
Sound can still be heard. Restart still the same. The MI logo shows up then slowly fades to black screen. Gone case? Xiaomi MI TV
Pay peanuts, get monkeys.
Anyway two years is a good run, just buy another XiaoMi. One ~$2500 TV can last 5 years plus, but can get 5 XiaoMi TV's (change every 2 year) which is cheaper.
deathan9el
Honorary Mentor
2 yrs is really a short life span :s22:
so far mine's lasted 3
& it's a Panasonic
not that it's spoiled but the screen starts to have lines at the bottom plus the occasional flicker :/
eeLoyH
Must have been a crash cause by acid.
kidding sounds abit like a power unit KO since it faded to black. Normally LCDs die by having funny pixels
savoirex
use chiur credits to buy from neighbourhood tv shop...
danny8x8
yalor. I also think liddat. No point buying expensive jippun one like Sony, cos electronics stuff nowadays not so reliable. Even with warranty, also troublesome.
Shdwfalcon
Fade to black means something on your power management died. Technically you can swap out the board and it should be good as new.
But since it is a cheap arse xiaomi, nust buy new one sua.
acidcrash
Yep fade to black. Restart a few times and now it doesn't show the boot up animation. Only the sound and can see the back light.
Shdwfalcon
If want to bua stunt, can try hunting down the board and replace it. But honestly soeaking, you are better off just getting a whole new tv.
Kunkka
dont mean to derail thread but i have a LCD monitor recently went kaput. i plug in power can last about 30 min then switch off. then i need unplug, change cable adjust abit , off power or let it rest awhile then can use another 30 min before turning off again.
danny8x8
if I kena something like what you described, I would try blowing a fan under it and see if it can tahan longer before it powers off.
jumping_pea
the last time i buy TV the salesperson tell me nowadays TV lifespan 4-5 yrs only.
kevinlaikf
In old days, LCD TV use CCFL to light up the panel, the panel itself only show image, but will not give out bright lights, the CCFL (aka mini florescence tube) make the image clear and bright.
LED TV replace the CCFL tubes with LED lights.
CCFL like your normal ceiling florescence light, will breakdown while LED is more lasting.
Stare at your black screen.. you should be able to still see the images, only they are not brighten.
In your case, the LED driver had broke down.
Kunkka
ok i try. but i sometimes adjust cable abit or switch cable can work again for a short while
