eno_lc
- Mar 11, 2005
No leh, nothing new in the houseDid you just bought a new appliance?
Should be same agency you call if there is a pump room water leak. Best to verify with neighbours if they saw what u saw.
Don’t say trip. Say power interruption. It is important to emphasize the power came back without you doing anything.
Yesterday and today holiday, didn’t see any electrical work going on outside
Somebody mining for bitcoinsomeone turn on some high power electrical device.
How old is your house?No leh, nothing new in the house
House got more than 10 years, but new wiring done 3 to 4 years ago during renoHow old is your house?
Hmmmm.....House got more than 10 years, but new wiring done 3 to 4 years ago during reno
There is nothing a “normal” end user can plug into a flat’s BS1363 socket that will cause the power dip or interruption seen by TS.
The cause is probably external to the TS’s home.
BTW TS we cannot rule out somebody playing punk and flipping the main service breaker along the corridor. This is a breaker switch that is outside your house and sits between the main supply and your power meter.
Put some flour dust on the lever and see if it is disturbed.
neighbor got same problem?
if not electrical problem then find a tang ki.
HDB, but new wiring done less than 5 years ago
