RedONE debuts in Singapore
SibehHL
i still think amazing plan are better for those travelling to m'sia 1-2 x a month save hassle buying additional addon for roaming
Personally I am on Amazing Plan for data usage in SG/MY and uses OneXOX for local calls in MY. The combination works well.
Youu are correct about folks who travel to MY once in a blue moon then there is no point for them to go on Amazing Plans which is quite costly if compare $/GB data with other MVNO plans.
gapboy
true there are also option to malaysia esim from wefly at $1.90 per day 500mb to unlimited which is much cheaper for "once a blue moon" travelers.
nel66778
https://www.redone.com.sg/promotion/3rdBirthday
Is anyone sign up WOW plan, how is the data speed?is it able streaming to online movies without lag?
lohsenglte
As usual, it depends on where you are.
But unlike unlimited plans, there's no hard cap on speed, so it's at full StarHub 4G speed.
lohsenglte
If I'm following this thread correctly. To sign up RedOne.
01. Visit a challenger store listed in https://www.redone.com.sg/support/locate_an_agent
02. sign up (bring the NRIC)
03. Will received the SIM card on the same day (then wait for PORT IN)
Is that correct?
Oh anyway happen to know the WOAH plans only pay $10?
From 7 Sept 2021 onwards, upon registration of the mobile line, there will be a SIM Card fee of $10 and a 1st month payment of your subscription plan required. These fees are payable upfront and non-refundable. The 1st month payment of your subscription plan will cover for the 1st month bill. Any remaining will roll over to cover the fee for the following month.
The $10 sim card fee can't be waived.
Also, min 2 bill cycle for redONE.
So it's min $30 spending if you want to just try redONE WOAH.
gnooliew
isn't TPG/SIMBA cheaper? and there is 1gb roaming. Or izzit becoz TPG connection sux
gnooliew
TPG is cheap don't expect great speed and low latency.. It is good for senior plan $5 a month..
S22ultra
thanks, as i suspected. I do like redone amazing 8. the data and talktime usable in malaysia is a good plus pt for the price if 5gb per mth is sufficient.
Richliao
Unlimited at 128kbps/0.12mbps can stream youtube? Zero1 is Unlimited at 1.2mbps right?
XiaoFu99
Do you mean 100mins talktime usable at both Singapore and Malaysia?
Meaning at Malaysia, I can call SG or MY number utilizing that bundle 100mins?
gapboy
Free mins can only call to malaysia from sg.. In malaysia is consider roaming calls.. Not inclusive in your mins
S22ultra
sullycoin
For the 3rd Anniversary WOAH plans, are the upsized data allowance (30GB for the $10 plan) permanent as long as you maintain the contract?
I know it's sort of asking the obvious here, but I've gone through the rather skimpy T&Cs a couple of times & that seems to be the case, but just want to be sure I didn't miss something...
Richliao
Yes...till you or redone decided to terminate the plan, according to cso I spoke to.
lohsenglte
Wa then redone throttled 128kbps really cmi.
It has never been marketed for use for anything other than basic texting.
Plus, you're alr richliao, need the unlimited throttled data for what? Just sign the $25/mth MyRepublic Unlimited Plan la, 5GB/day uncapped leh hahaha, as long as you're ok the deprioritized network on M1.
