86technie
- Jun 8, 2006
I agree TS should consider TV.Sincere opinion - just get the biggest TV you can reasonably afford.
Projectors are too finicky - the lamps got life limit one, the lumens not bright enough to use in a lit room, must find a good spot to mount the projector, must find a good spot to put the screen or if projecting onto a wall must make sure the wall surface is matt and ideally white etc.
Projector wise depends on many factors especially room.
If room is well lit with sunlight than the picture will be dim so it is recommended to install in a really dark room.
Lamp wise does have lifespan as well as depend on your usage. If 24/7 or long usage the lamp will wear out.
There are Casio LED projector as well as Laser projector like Sony which does not use lamp.
The Casio will be cheaper but picture isn't very good.
Sony laser projector are expensive and not recommended for small rooms like HDB flats.
TV will be better choice for homes unless office, classrooms and auditorium etc.
