Which one will you pick? TV or Projector
The_King
this design should work but my bed from queen to super single
Laneige
their room at treated, like the wall dont reflect much light,their projector are high end.
mine at most 1.5k. no fight at all
Means the tw designer that recommend Canon is most likely smoking lo, make me thought projector has hope.
someone told me China one is gd. I don’t know got Hao siao or not. Or the ‘good’ Is value for money or specs v ky kind n cheap , gd
The_King
projector is for the movie theatre exp, it nv about picture Qua
carey
Cannot la. The grays make it look so muddy. Projector's huge flaw is it can never render blacks decently.
Sure got some compromise one unless you are willing to splurge on a high-end laser projection
Even for TVs, the black is also not really that black
Clearnfc
Be it tv or projectors, black will only look black when room is dark.
Yes, JVC are known for their blacks but you need a bat cave for that. Else, it doesn't work. ALR screens only work to a certain extent.
Darkshadows
I have contemplated on getting a retractable projector hidden within the false ceiling but ditched the idea. Lots of moving parts (higher chance of breaking down) plus maintenence of projector will be too much hassle to me.
