who use metal bed frame?
VannieP
thread tio hijack become NS thread.
zzzzzzz
the wooden frames nowadays got lifetime of 3year only ....... because the black color artificial cloth 'non-woven-fabric' the same type as use on mask .... it disintergrate after 3 year lifespan ...... that fake black fabric is widely used to cover ugly plywood and empty frames in chair sofa bedframe
can buyed those plywood from outside shods and ownself sand down and lacquer it
:frown:
zzzzzzz
my times is kns spring bed frame and sibei thin matress.
only bmt got the thick mattress, go to training school and unit is use the sponge bed
but no issue to me cos my own home was also using sponge bed that time cos family poor
:frown:
Kiwi8
Deluxe Member
My wife ordered 2 single bed frame on shopee, I think was around $300 plus. Had to assemble ourselves. Quality quite good, but cos very heavy, u probably need to put something to protect the floor, my tile got scratched.
U need to put rubber protectors on the legs
zzzzzzz
the one i slept in bmt is the same, i remeber the bolt got one loose the bed frame keep become crooked then i use ET stick whack it back it but it will keep coming out
then i remember i tell my papa and he say i should use aaron keys to screw in instead of whacking it in which spoils the bolt
:frown:
zzzzzzz
but one thing i dont like about metal bed frames is that usually they are not 4 legged for queen bed
usually is 6 legged or more
:frown:
tankgunner
Mentor
:frown:
My time was the green double deck one.
