Recommendation for Toilet Bowl
ataurus
Recently need to renovate toilets.. Also searching for toilet bowl... Many brands are just local or Malaysia brand and made in China or Thailand like Roz, baron, tiara, Vera, Otto etc... Want branded are American standard, Johnson S, Toto etc... . Rigel is local brand also... Anyway.. Ordered Vera a32 toilet bowl with bidet for 500... I looking at taira also.. But compare side by side.. Vera the ceramic is more white.. While other like look yellowish..
Anyway I saw the best deal is Lazada got rigel brand toilet bowl with full back to wall for $26x..only...want to buy that but mine wife fancy 1 pc type.. And we need the gap behind for the water source for bidet.
Hi, how is the Vera toilet that you ordered? Looking for replacement and Vera looked/sounded good to me. Does yours have vortex?
Nakedtoes
Vera ceremic.. Is the full brand.. Mine is with the tornado flush.. Frankly speaking.. Is not bad.. But some big sh1t might still need to flush 2 times then can.. Mine initial model is the one rimless and nomal flush.. Because the supplier do not have the collar stock for mine toilet so they "upgrade" my toilet bowl.. If u really wants to buy I see online is cheaper.
ataurus
Thanks. The models I saw at Balestier say 10 year warranty and Vortex tecnology, not tornado. Where did you find yours? Different supplier use different parts?
Nakedtoes
Same same..should be the same.. I got mine from Tapz & Coffee opposite Jalan Besar food center.
tortoise18
Hi looking for rimless, tornado. Preferable 700cm and below length.
Any recommendations? I was recommended tiara
tortoise18
Went to bathroom warehouse recommended tiara 535 said rimless and tornado flush. But went home to check doesn't have tornado lei?
orhanzi
bto toilet bowl good enough? should i replace ? if replace, can recommend toilet bowl below $400 ea?
ataurus
All tornado toilets have no traditional rim by default and in that sense are 'rimless'. But not all rimless toilets use a tornado flushing design. Maybe your shop meant Tiara 935 or you heard wrongly. Think only their 9XX series have tornado flush.
ataurus
Any toilet bowl can be used la, only how comfortable it is and how long it lasts. Also if you or your family has special needs, eg very tall or wide, Maybe check the water usage of the model they gave? If it's not acceptable, can consider replacing it with a water saving model.
Darwinson
Hi guys. I hate to go through this discussion again. Literally bought two toilet(tiara 530) last year. Now one more time for another house. This time only need the cheapest one piece toilet which has - wide seat.
I mayfair 8116 also can la. It’s about 238. Got cheaper better.
Any suggestion.
Mystyque
Any suggestion.
wah gx gx so rich can afford multiple properties in current climate :o
dontwastetime
I'm using the Tiara Tornado, i'd say generally the short flush is good enough for most loads.
Hi does the tonado spill up the rim ?
I used my aunties Magnum tornado, the water keeps going up to the top of the rim, quite disgusting
dontwastetime
Update: After 1+ week of moving to my new place, I'm loving my AS toilet bowl. Flush is powerful and only requires a single flush to clear. No splashes outside either which I had a slight phobia at first given how powerful the tornado flush is lol
Hi is it No splash on the seat
or
the porcelain rim ?
I also phobia
cutieprincess
hi! any shops recommendation for toliet bowls that carry toto and american standard? prices are competitive too? haha thanks!
PARKRANGER
Bought baron w888
Just little over 1 year, the soft closing seat is spoilt
Supplier said waranty for seat is 1year
Anyone knows how to diy repair?
I can’t get seat to unlock from the hinge
So see if chance for diy
