TanKianW
- Apr 21, 2005
It is not possible with Singtel 2Gbps plan. For 2Gbps plan, the main router will be the ONR, and it can not be bridged by defintion of the 2Gbps plan.
Unfortunately more and more people will sign this Singtel 2Gbps plan and realize this issue due to the push from Singtel side.
Once you are using the Singtel ONR (unbridged), there is really no point to buy routers like GT-AX6000 with powerful CPU since you can really only use the Asus router as AP in order to avoid Double NAT; or you may be able to live with Double NAT (if you set up the Asus in router mode) if you are only browsing the internet and consume video streaming.
Ref: DOuble NAT
https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
2Gbps really very good to sell.
Most consumer hear 2Gbps, think it is faster liao. No need to explain more. Price it just a little bit higher than 1Gbps. Consumer mind thinking.....value for money for 2x 1G speed at less than 2x 1G price, most will bite.
Recently more and more ST subscriber came here to post after getting the ONR for 2Gbps.
Hope more check out the forum before signing up.
