- Sep 16, 2018
Merlin himself said that there is a bottleneck. I personally tested myself and yes, I can't get full gigabit speeds using the built in speedtest
Thanks. Interesting to know that. What about the latest ARM Linux version from here?
https://www.speedtest.net/apps/clihttps://install.speedtest.net/app/cli/ookla-speedtest-1.2.0-linux-aarch64.tgz (aarch64 for RT-AX86U/88U/etc)
I was using the below version.
https://install.speedtest.net/app/cli/ookla-speedtest-1.2.0-linux-armhf.tgz (armhf for RT-AX56U/58U/82U/etc)
FYI, I had no issue getting full wired speed from Ookla SpeedTest last time when using Raspberry Pi 400 (with BCM2711 Quad Core Arm Cortex A72 CPU at 1.5GHz/1.8GHz) running OpenWRT. BCM4908 (Quad Core Arm Cortex A53 CPU at 1.8GHz) will of course be much slower compared to BCM2711 but I was hopping it was just good enough.
BTW, the reason I did not go with RT-AX86U but RT-AX82U in the end of 2020 was that I already set my eye on OpenWRT/pfSense using Intel mini PC at that time, even though I know RT-AX86U would win over RT-AX82U by quite a bit in terms of CPU power and even wireless performance.
