jericho75
- May 24, 2013
cut cost no fret, as long as PLP is tokkong, wont tio chop
If ur tenant dunno how to plp tio pok how?
Is it? Depends on CPF balance and loan amount bah. My new neighbours borrowed from HDB.
Buying properties is a long term commitment, have to think of various factors carefully....just buy an affordable unit.
3 month sora can only go as high as daily sora.. it's increasing because have not reach daily sora % now which..See 3m sora. Sure increase one. If banks can give 3.4% fd. Means they know something.
den is ti gong po bi good the luck lorIf ur tenant dunno how to plp tio pok how?
Etc 2.41% now will increase to 3+%
Based on the Fed's DOT plot, rates are still forecasted to rise into 2023 with any expectations for rate cuts to happen in 2024. Of course, Powell is under some pressure from the politicians not to raise rates by 75 basis points. We shall see based on the next FOMC if that comes to pass. Expectations are for a 50 basis points increase for 1-2 Nov FOMC.
In summary, home rates will still continue to rise. But it looks like most of the household balance sheets here will be able to tank it.
100bps will be about there based on 2 yr yield but likely spread over Nov and Dec.Powell should ignore Brandon and hike by 100 bps.
He didn't dilly dally. It takes time for rise of interest rates to affect inflation with a time lag of 1year approx to kick in. It's not a immediate cause and effect where if he raise 100bps today, tomorrow inflation will drop 50bps. Alternatively, he can do Volcker shock by raising 2000bps immediately but what will be the consequences?Powell dilly dally cannot bring down inflation one. need Volcker type of shock until ppl dun dare to borrow then inflation will drop.
notice how the 2 yr yield is able to pre-empt the direction and magnitude of the fed funds rate.
Read HWZ Forum Rules!
We talk so much and tell fed what to do no use de. The bond market is very smart on this.actually he hike so much no impacts u know why? balance sheet only reduced by 200 billions after so long. when they qe time no jjww one. jitao drop rates from 3% to zero within a month then print 120 billions very quickly. they better buck up else dedollarization is coming at a faster rate.
This chart is talking about how the fed funds rate closely follows the 2 year Treasury yield, nothing to do with yield curve inversion.actually yield already inverted liao.
How is that a good thing? Is it it will become 4.55 soon?luckily i changed my condo bank loat fixed rate to 3.55 from floating sora 3 months. i just got the loan last month
fixed rate 1st for 2 year then redeem loan after why not good??How is that a good thing? Is it it will become 4.55 soon?
