Teo Ming Ern
- Jan 1, 2000
This runs the ZUI ROM based on that firmware serial. Which runs Google stuff without any problems.Hi
Plan to get a 2nd hand Xiaoxin Pad Pro 2021.
The current firmware is 13.1.56 ST
Is this the original Zen CN firmware or?
And what is the latest firmware version for the tablet now?
Pr i should get a Pad pro 2022?
Thank you.
I just did a random price check at tanteo's listing on Shopee and found the following:
1. Lenovo Xiaoxin Pad Pro 2022 (8/128) = $558
2. Lenovo Xiaoxin Pad Pro 2021 (6/128) = $409
There's a $150 premium on getting the newer model but you do get 2 GB more RAM which I think is really the most useful difference but it remains your choice whether that extra RAM is worth that much to you or not... plus that premium gets you maybe better screen (I don't feel it's that significant but since you can't view the screen, then you've just to go by the review in the viol provided by Gregory Choo)...
How much is the secondhand Xiaoxin Pad Pro 2021? Is it priced low enough to make it worthwhile - the primary advantage I feel being you get your tablet instantly... ha ha...
