Hi everyone, wanted to get some advice on upgrading my home network.
I am currently using a single AX55 in the study room, with multiple smart devices connected to it.
I noticed the signal is not so good near the kitchen end and further inside the MBR.
Saw a few recommendations to put a better router into DB box, turn off the WiFi, and set up an AIMesh outside with another 2 devices (since I already have the AX55).
Wanted to see if there are any recommendations for the respective devices. Or suggestions for the layout.
- Have LAN ports in every room
- Study room is where my work devices are so going to connect via LAN
- Planning to use LAN for my SMART TV / TV Box out in the living room
My humble recommendation
Disregard the brand 1st, You need mesh capable network router which support both WIFI and Ethernet Mesh configuration.
Placement:
- Most powerful WIFI router should stay in DB box connected to ONT. (Providing WIFI and Processing all network packets going in and out of internet)
- The other WIFI router can be placed in Master Bedroom (using Ethernet Mesh).
