later more like reskinned D3![]()
Point noted, thanks yah.More than enough for diablo 4... It's a top down arpg after all, not a 3D action game where you have to render multiple camera angles real-time. Save your money for the monetization, you'll need it.
good deals are hard to resist i agree, D4 still early though u gonna whack ur hand until not itchy 1st haha, requirements not yet released, you have to wait abit, worry wait u buy 2060 become minimum requirement for 1440x only, from what i see abit reskin but yet looks newer engine based on the graphics...Yup you are right, just that i saw a few good deals for 2060 makes my hand itchy, hahah
but I really need advice on whether my 450W PSU can hack a 2060 super anot ah?
I read somewhere that it's based on a new engine lah, but then again as Rogue mentioned, it's not a 3D game like cyberpunk lah, so i think 1440p requirements should not be that crazy.good deals are hard to resist i agree, D4 still early though u gonna whack ur hand until not itchy 1st haha, requirements not yet released, you have to wait abit, worry wait u buy 2060 become minimum requirement for 1440x only, from what i see abit reskin but yet looks newer engine based on the graphics...
1440p and 4K will definitely require above recommended requirements since on a bigger screen... default we are talking abt 1080p only...
HiHi TS..
Did you try the beta test open to selected people? I was fortunate to get a slot earlier and tested it on my ryzen 5 1600 with gpu 1070 and 32gb ram. I would say I still had some stuttering and I was playing on low to mid settings (if I remember correctly)
Hence I personally upgraded to ryzen 7 5700x and a 2nd hand 6700xt. Hopefully that's enough for me.
You will do well to consider again when specs revealed but I suspect u might need to get a new rig.
I was playing on my uhd 4k monitor... Not sure what resolution I was running at.Hi
Tks for the feedback!, were you running at 1440p?
Nope I didn't knew about the beta testing.
I think I might need to get a new rig liao sia, haha
I see, can you share how much you spent on your ryzen7 and 6700?I was playing on my uhd 4k monitor... Not sure what resolution I was running at.
Maybe was 4k that explains the low fps
Ryzen 7 $229 newI see, can you share how much you spent on your ryzen7 and 6700?
ooo 6700 400 not bad price...Ryzen 7 $229 new
6700 $400. 2nd hand
tat time d3, intel 5 cannot make it... need at least intel 7Ryzen 7 $229 new
6700 $400. 2nd hand
where got i5 cant run d3?tat time d3, intel 5 cannot make it... need at least intel 7
Ryzen 7 $229? sic?
dunnoe ryzen 7 enough anot? or need ryzen 9?
multi tasking.where got i5 cant run d3?
climbing in the background isit?multi tasking.
Release date is 6.6.2023. 6 months away. Maybe wait and see? Blizzard also hasn't announced the System Requirements for Diablo IV.
Have no idea what will be a good upgrade at the moment. 2nd hand cards won't be affected by GST 8% next year so don't have to worry.
