Upgrade or New Setup for Diablo 4
limbs03
2nd hand 3070 or 6800 if you wanna do 1440p general gaming.
~450 sgd or lower .
Diablo usually dun need very high specs to run even at ultra cause they need to cater to console performance so you probably can reuse your CPU and upgrade ram to at least 12gb++.
Save the rest to buy crappy money sucking d4 season pass which they introducing soon lol.
Hi
Thanks for the recommendations! Ok noted on the CPU and ram yah.
For the GPU, my CPU and MB don't support PCIE4 leh, so I think it's abit overkill to get a 3070/6800.
I think the RTX2xxx is furthest I can push my current system liao.
I hearsay the earlier AMD GPUs have sucky driver support sia, so I think I'll stay away, hahah.
zensushi
Moderator
Moderator
I am also wondering if my current rig would be able to run Diablo 4. Otherwise, would need to get a new config. 😭
limbs03
I tried the open Beta, my current rig confirm cannot run 1440p.
I saw a deal for a new rtx 2060 super for $350, from Inno3D.
Anyone can share experience with these smaller companies? Like Colorful and Galax?
ragnarok95
Senior Moderator
Senior Moderator
Carousell right? I saw that same deal. But 2nd hand RTX2060 is going for 200+ with warranty. I suggest going for that. Cos S$350 range can get a RTX2070 2nd hand.
kaixax555
Galax is basically Palit, so if you know who Palit is you know what to expect from Galax as well
Colorful I have heard of as well, makes whacky coolers sometimes but should be decent
wongminmin
colorful gpu is decent as in hardware and cheap cheap, just that finding the driver will be kind of hard. :censored:
Koenig168
Galax is a bit of an odd fish. Most of its product line is budget but its Hall of Fame line is top-tier. I have the Galax GTX 1070 Ti EX-SNPR which has some aspects of the HoF line and both build quality and performance is top-notch. At stock power, the GPU can already OC to 2 GHz.
Colorful is relatively unknown in Singapore but is hardly a small company. Colorful is the dominant GPU brand in China.
SolarBurn
my 1080 also struggles with Diablo 4, shag... thinking wanna to buy new com or not...
limbs03
Yeah on carousel. So it's about $250 for a 2nd MSI vs $350 for brand new Inno3D.... cannot decide sia, haha
limbs03
My current 1060 is from palit, it's about 4yo and showing signs of dying liao. Sometimes doesn't generate output at all.
Do gpus from the bigger companies like Asus, MSI, gigabyte last longer?
Palit is from china also isit?
86technie
If you are looking for RTX 2060 brand new, Global Cybermind is selling them below $400.
It's ASUS RTX 2060 Dual model.
Psycovirus
How about consideration of RX 6600, ASUS Dual AMD Radeonā„¢ RX 6600 8GB GDDR6 [$370]. It should run 1440p at 70+ FPS and 90ish with FSR Quality.
Aftershock has an event on Friday, 31st March. Selling 3060 TI at $499 with special voucher from their tiktok channel. Limited numbers so can consider that too if its within your budget. It may just be a marketing stunt so won't hold my breath for it.
kaixax555
I was going to suggest this as well, but considering that ts is using an old kaby lake system with only pcie gen 3, it may end up slower than a 2060 super with full x16 lane support.
This one has full PCIe lanes no meh
It's the 6500XT that is gimped
limbs03
Guys....the inno3D one dropped to $300 liao, haha
Check with you guys, driver updates come directly from Nvidia isit?
limbs03
Hoot liao, wish me luck, haha
Just to document and for sharing. I think I'm all set for 1440p medium settings!
I5-7500 on ASRock H270M ITX
NH-L9i cooler
Silverstone SG13
Palit GTX 1060 3GB Inno3D RTX 2060 super ($305,new)
G.Skill 2 x 4GB DDR4 2400CL15 G.skill 2 x 8GB DDR4 ($48, 2nd hand)
500 GB M.2 Nvme SSD
Corsair SF450
