- Sep 16, 2018
Hi, i'm using wireless between the 2 mesh nodes.
Sure, i will get an ethernet cable to test out the speed and revert back.
But if i get a new router will the speed be faster?
Yes if you have the better wireless device, say Wifi 6 enabled device.
Good wifi 5 router with good wifi 5 2*2 AC 80MHz device, at close range: 500-600 Mbps
Average AX3000/AX5400 Wifi 6 router with average 2*2 AX 160MHz device (eg: cheap Intel AX200 adapter), at close range: 600-800Mbps or even higher
