- May 15, 2000
There is at least one elevator from the ground level.I don't know got any upgrade, last time I only see stairs no lift. If no lift, big luggage jialat.
If its for saturday of songkran though, it wont be busy. If normal saturday, be there by 4:15 p.m., means you should be leaving latest 3 p.m.My standard is 2hrs + 1hr, 6.15pm traffic will be worst, may need to add more time or take other transport.
My standard is 2hrs + 1hr sure fine. Unless peak hour then need to add more time.If its for saturday of songkran though, it wont be busy. If normal saturday, be there by 4:15 p.m., means you should be leaving latest 3 p.m.
Just tell them your flight timing will do.Thanks all. Can I also check if I wan to book private transfer for pickup at airport, flight landing at 1.40pm, what time should I ask the driver to come? Estimate how long will take to clear custom?
Reply in redHi all I am going on next wed, still excited
if my return flight is 1050am on 23rd
I have to reach airport by 750 right wrong, 2hrs reach airport can already
if My hotel is Phrom Phong area, should I request from airport transfer from my hotel
or I just wake up early and take BTS to airport? When you go there get a map or digital map to see the distance or use google to check
what timing is advisable for me to leave my hotel? Please advise 2hrs + 1hr
For bkk you know they advice people to go airport 3 hours in advance ?Reply in red
Didn't notice.For bkk you know they advice people to go airport 3 hours in advance ?
so i need to wake up at 6am...okkMy bad, time change.
Just check;
Bangkok’s main airport, Suvarnabhumi International, is advising international passengers departing from Thailand that they should be at the airport, ready to check in up to three hours prior to departure.
The airport has outlined certain peak times where a large number of departures are scheduled and tells passengers to prepare for long lines.
DEPARTURE (11pm-11:59pm: 19 flights with 4,200 passengers
Non- peak hour 2hrs in advance is still ok.
this is just an example of the super peak period. Morning is super peak also between 10am-12pm.My bad, time change.
Just check;
Use your phone as time guide. Thailand slow SG 1hr.and thailand is one hour eariler than sg....
Guys I need to ask u all something, I have concern abt the check in process on the Suvarnabhumi Airport on my return, it is 10.50am flight (Thailand time)
Have any one did the online web check before?
How it work? is it I just do online checkin on my app and then I can collect the boarding pass there?
As I dun have the printer when I am at Thailand, do I need to print the boarding pass myself?
Then if I do the web checkin, do I still need to go there early and queue on my way back?
Please advise
is it better to check in online? nobody use that?Just go queue at the counter and get your boarding pass.
Please advise
