windwaver
- Apr 28, 2000
Updated on 1st page.They update at fixed timing, it’s not a live update…..
This morning is at 8am, and it reflects those who applied since 5pm yesterday…..
Think mainly payment issues so far.Hdb should make a statement about system slow..
Apply rate increase from this morning 0.1 to 0.5....
Wait time one minute..
Oh Dear hdb staff this morning report duty then fix the system...
yr HLE still active is it? usually can only have 1 HLE/HFEThought HLE can be used for May but see wrongly, now try to apply but keep getting this error.
"There is a need to verify the details of the application. Do write in to HDB via e-Feedback and quote "MOP = E" before we advise you further."
WTH?
WTH?
Does anyone know when the BTO result would likely be out?
should be mid of July for this BTODoes anyone know when the BTO result would likely be out?
Can check if you have managed to solve the problem? Thanks!having the same issue. zzzz
hi, i've done the prelim checks already and applied for HFE letter. it means my prelim is done right? but idk why they keep saying i dont have the prelim letter.
Soccer fieldWhat was the previous site for, before they intend to build upcoming Serangoon project?
as long as you login and see hfe prelim..fug hdb..
they come out new system sure never test and just go live one then screw up
