AMD Ryzen Notebook discussion | Intel or AMD for notebook? AMD Excellent CPU+GPU performance, sharing concurrent models reviews.
iamnagel
Hi.
I've just got a Lenovo Yoga Slim Pro X with 2 USB-C Displayports.
I tried connecting to external monitor with a USB C to HDMI cable.
Monitor is Dell 2421H (1080P) with only HDMI inputs.
While the notebook detects the monitor, the monitor does not receive any signal.
Does this mean I need a 4k monitor?
I tried connecting to my 4k tv with the same cable and it is able to display my notebook.
Thanks in advance for any advice.
halocast
Hi.
I do not think it needs a 4k monitor for it to work.
U tried playing around with the display settings in your laptop?
Maybe the 1080p monitor needs a firmware update?
:o
iamnagel
:o
I figured it out. I had to change the settings in windows for external monitor to be 1080p and 60hz refresh rate.
gld998
Erm ideapad 5 pro
https://www.lenovo.com/sg/en/partner/bplocator/
IdeaPad 5 Pro 16ARH7 | 82SN00C6SB
16" 2.5K (2560x1600) IPS 350nits Anti-glare, 100% sRGB, 60Hz, TÜV Low Blue Light
AMD Ryzen 7 6800HS Creator Edition (8C / 16T, 3.2 / 4.7GHz, 4MB L2 / 16MB L3)
NVIDIA GeForce RTX 3050 4GB GDDR6
16GB Soldered LPDDR5-6400
512GB SSD M.2 2242 PCIe 4.0x4 NVMe
FHD 1080p + IR, ToF Sensor
Integrated 75Wh
135W Slim Tip (3-pin)
Backlit, English
Storm Grey
Around 1.95 kg
Wi-Fi 6 11ax, 2x2 + BT5.1
Windows 11 Home 64
2Y Premium Care
NO THANKS!
flowerpalms
Integrated 75Wh
Backlit, English
Storm Grey
Around 1.95 kg
Windows 11 Home 64
2Y Premium Care
NO THANKS!
Just use for 1 year only. I will buy better desktop for my own house next year
shadow84
Any usable codes from Lenovo? Looking to get basic laptop, maybe ideapad 3 series. Below $1k.
huytoan132
Good time to buy, Carousell is flooded with decent laptops with good price & still have warranty.
<1k4 can buy Legion 5 Pro RTX 3060 already.
huytoan132
Dun need gaming laptop and trying to stick to <$1k.
Then you try to look for Ideapad 5 Pro in Carousell, decent built quality & specs at this price point.
No good deal buying brand new. Retailers keep high price to offset for low demand
vofzxy
https://shopee.sg/Asus-Vivobook-16X...-7-Win-11-Home-Laptop-i.637668725.22119999391
Asus Vivobook 16X | 16.0" WUXGA | Ryzen 5 5600H |16GB DDR4 | 512GB SSD | AMD Radeon Vega 7 | Win 11 Home Laptop
● Windows 11 Home (64-bit)
● AMD Ryzen™ 5 5600H Mobile Processor (6-core/12-thread, 19MB cache, up to 4.2 GHz max boost)
● AMD Radeon™ Vega 7 Graphics
● 16.0" WUXGA(WU) 1920X1200 Wide View
● 8GB DDR4 + 8GB DDR4 SO-DIMM
● 512GB M.2 NVMe™ PCIe® 3.0 SSD
hi guys, can i ask for your thoughts of this particular listing?
i saw checking out the idea pro 5 idea on carousel,
can i confirm if this is the model that is being reference to -
Ryzen 7 5800H RTX 3050 Lenovo IdeaPad 5 Pro Gaming Laptop
i dont particularly need gaming specs, i dont game but in the odd blue moon occasion i will need it to run maybe OBS/VMIX ... otherwise it would be just work/office (and MS office + surfing stuff) stuff, also as a back up for family laptops that uplorry (INCASE!) and running windows)
my main laptop i currently use everyday is my M1 MBP but is giving me parallels issues
budget wisse -- hopefully <1.2k, i recently saw the laptops around this price at Best Denki,
up to 15" and it feels light, but unlikely for me to bring travels and all that carrying around.
