Any good renovation contractors to intro
ClassicToe
Can ping me if need, but he is now a home based contractor, no longer has a showroom. only if you're comfortable.
As for hacking away storeroom, advise you keep it. I was tempted also but I left it, I just overhauled the whole place from pipes to wires and all tiles/windows/doors/gate.
Hi, can pm me the contact too? thanks!
CG1996
Mine's completed liao, 2-3 weeks ago made the final payment, still got on-going rectifications and he still otang me a light bulb lol.
Hi Are you happy with renovation? Would you recommend your contractor?
~sabaisabai~
Hello,
Genuinely sharing a contact for direct contractor work.
Responsive, and genuine .
My place is currently under renovation and would be more than happy for you to see.
Sharing to make renovation more affordable .
can share here?
cryn79
Hello,
Hi Petslave,
I am looking for a direct contractor to reno my kitchen.
Can pls share yr contractor's contact? Thanks!
Petslave
Hello.
Sorry wasn't active at this platform due to work.
Have replied all in PMs.
Would be happy to share and invite you all to see the progress at my unit.
Believe we should share such good contacts around to ease the burden of meeting unethical contractors and more importantly, affordable.
usernameinuse
Hello.
Hello, possible to share the details of your contractor please? Been looking at quotations from ID but seems like ID doesn't really value add?
CG1996
Hello.
Hi,
Can pls share yr contractor's contact? Also, would be happy to see the progress at your
unit. Thanks!
Peterho69
Hello.
Hi... Pls share your contractor contact. TIA.
wievi83
My renovation was completed in 1 month and 1 week. I didn't do any tiling/wall hacking so most of the work is actually in carpentry on the living cabinet/tv console, 3 bedroom wardrobe, study room partition, and master bedroom headboard. Also have the additional aircon works, painting, plumbing, and electrical works as well. The quoted price is cheaper than the one I get from L*vsp**e and St***y Ho**s***d. The latter one told me that my reno might take 2-3 months but the ID that I engaged estimated it will take roughly around 1-1.5 months and he managed to complete the reno ahead of schedule
Overall, I'm quite satisfied with my ID's work since the carpentry result is top-notch. The carpentry fabrication only took roughly around 2 weeks. One thing to take note of is that he might be a bit slow to reply to messages since he is also working on many different reno projects, so you can't expect an immediate response from him every time.
Just PM me if you're interested and I can share his contact
simymxh
Please PM me the contact details and the per foot run cost for carpentry work. Cheers!
NoTimeToWaitAr
hi all, does anyone know if i'm going to remove the existing built-in carpentry, will it affect the floor tiles? I went to 2 ID and got different answer.
one ID said the carpentry is drilled to the floor, another one said typically use silicon so it will not affect the flooring when the built-in carpentry is removed.
wacko
it depends on what type of carpentry. most carpentry do not require drilling into the floor, but in certain heavy duty carpentry design, there can be drilling done. you will only know for sure when you start hacking the carpentry.
NoTimeToWaitAr
Thank you.. seems like i need to have some contingency in case it damage the existing tiles and i need to find back the same design
Kaswerns88
Was lucky to come across this pretty steady contractor, father has his own carpentry business so for whole unit projects, he usually does it. More contractor style so don’t expect the usual “ID type of works” for example 3D, mood boards etc.
The price for our 4rm bto which included vinyl flooring from floorxpert, sintered stone kitchentop, carpentry for top/btm cabinets, redoing of both toilets and master wardrobe with glass doors. All in was around $40+k which for the materials used, did seem like a pretty good bargain.
Can pm the contact of the contractor ^^
siriusb
Hello.
Hi @Petslave, please share with me your contractor's contact. thank you!
siriusb
Hi @wievi83 , please share with me your contractor's contact. thank you!
StarisX
Hi anyone can share with me some direct contractor? Wanna do up kitchen during HIP.
