Installing Fibre Terminal Point inside Utility Room
Liang32
Hi all networking Gurus
I need some urgent advice please
Juz got a resale 3i HDB with a utility room behind
I'm gonna use that utility room as my entertainment/guitar room so basically all my PC, gadgets and stuffs will be in there.
Went to ViewQwest @ Suntec yesterday wanted to apply for the wifi mesh with Asus ZenWifi Mesh plan, but the guy adviced me not to apply 1st before laying cables.
So my concern is, am I able to install an FTP inside the utility room?
am I able to install 1 more FTP at my living room to cater for smart TVs, wireless sound systems etc etc ??
and even so, becoz of the structure of that utility room, when I close the door, the wifi outside will definitely be bad.
not to mention in the middle is my kitchen with alot of cabinets and stuffs, although is an open kitchen but I guess the Wifi will still be affected?
I attached a floorplan for better understanding.
Please help
Thanks all!
firesong
Deluxe Member
Just lay an ethernet cable to cover your utility room. Then connect a switch and Access Point to cover your intended devices; it should give good coverage even with the doors closed.
If you already have an existing FTP at the entrance, moving it costs about as much as laying a LAN cable anyway.
A 2nd FTP means you need a 2nd Internet plan, which isn't cost-effective.
xonix
Yup I agree with above post. Just lay an ethernet cat 7 cable to utility room.
Liang32
Hi bro
Thanks for reply
My problem is
When the door is closed, there isn’t any holes to run the ethernet cable.
And the utility room walls cannot drill hole as they are thickened beams.
Unless I drill the hole on my door, which kinda defeats the purpose of being soundproof?
sacredrays
Hi bro
Thanks for reply
My problem is
you no need to make a hole for the fibre cable if you want to put a ftp inside the room?
sacredrays
Yes I need to.
I juz double cfm with Netlink that its ok to install an FTP inside..
if you put ftp there. you still need to put lan cable to outside for your house internet outside the room. unless you signing up for 2 fibre plans..? (assuming you got 2 ftp in your home)
pulling lan cable into your room is more ideal. end point in your room can be a network switch, or AP with lan ports (or router in AP mode), etc etc.
Hafi
FTP is free up to only certain metres to your house, if you want to lay the fibre all the way straight into your utility room it'll be at your own cost... it is like living rm + kitchen = 15m
Hafi
Hi bro
Thanks for reply
My problem is
you can terminate the CAT run at your door front then extend the rest of the run with flat type CAT cable which should slip through your door gap easily.
limck
when was the upgrading done to add the utility room?
my parents' place (similar layout) was upgraded in the early 2000s (I think 2002) and the utility room has another telephone point added along with a SCV point.
If your utility room also has a telephone point, what you can do is to replace the CAT5 cable (used for telephone) with a CAT6 or CAT7 cable to terminate where the FTP will be and then change the RJ11 jack to a RJ45 jack. Then you can just leave the FTP in the original living room. If you still want to shift the FTP, you will need to contact Netlink Trust to shift as your house is likely following the old IMDA code which only allows NLT to shift the FTP.
alex22
Call up NLT tell them u wanna put the tp in the furthest room.
Expect they drill through the door frame corner.
Just pay the 150 plus plus fee
Liang32
Oh thats a good idea too!
Hmm, but there will be visible cables underneath the door.
But bobian also, cant drill door
Headache..
Liang32
many years ago
Mine is a very old resale flat, 1973.
So inside is totally no points de.
Liang32
$150 i can buy my own drill and drill sia
Hahahaha
Hafi
Headache..
the FTP point relocation could easily cost you $400- $500 (could be more if the contractor wants to chop you)
Another alternative is to run fibre patch cord (20 metres $20+) but take note cannot bend much, need to hack holes through the beams all the way till your kitchen. If FTP relocate too much cost can do this instead, buy the patch cord yourself then find a freelancer/contractor to lay.
https://shopee.sg/M1-Starhub-Singte...-Patch-Cord-5m-10m-20m-i.131332496.8386263957
Hafi
Headache..
if you door is the hinge type sure have gap can slip through the hinge side wat, no need to place underneath the door and your door can still open/close as normal.
Liang32
hmm the question is though..
Am I able to drill holes through the beams?
I did contacted and confirmed with Netlink that they can install the FTP inside the utility room.
But thats only surface drilling to install the switch/plug
Drilling thoroughly through is another question.
Duno if HDB will come after me..
