YongSG
There’s a few UniFi 2.5G POE+ switches. But yes, it’s needed for the 6E APs as the UDM Pro does not have POE+. I’m not sure if POE+ injector would work as it may limit the transmission to 1G.
One practical consideration to note (other than pricing) is whether to go for fan or fanless (silent cooling) switches due to the noise.
Fanless and affordable (just for 6E AP) would be USW-Enterprise-8-PoE and optionally add a (Layer 2*) USW-Aggregation if more 10G ports is needed.
ONT > Gateway/Router (UDM Pro) > (using LAN SFP+) USW-Enterprise-8-PoE
@YongSG able to share ur WIFI 6 speeds with the U6 Enterprise on 2.5G?
Will do a speed test soon, the U6 Enterprise just arrived today and waiting for my to unbox
matthew5025
I get ~ 1.6Gbps both ways on a single client
YongSG
Here is the Speed test i did.
- Laptop 2018 | with upgraded intel AX210 wifi Card 6E
- Unifi AP U6 Enterprise
- Unifi USW 8 PoE+ Switch 2.5G Lan with 10G uplink
- MyRepublic 10G Fiber connection via Unifi DreamWall
NoAppleNoTalk
Anybody uses starhub 10gbps ONR Nokia XS-2426X-A? Cant seem to locate the fiber port.
