[OFFICIAL] Singtel's GOMO discussion thread
tazzi80
Hmm. The databank data would automatically be used when u reach cap for the month. Then I can just send max data at the beginning of month to the data bank then.
chenaz
GOMO not good. Me and my wifi both same phone same GOMO. He roaming at Msia working. Mine didn’t work.
Lucky I got simba as backup , best is no setup required somemore.
GOMO i set to Hicard also not working
kelvinti
I think Singtel mvno’s generally all have issues during peak along that stretch of circle line all the way to Bishan.
Second that. Even the "Heya by SingTel" also the same as I have noticed espcilaly around MRT stations and inside its cabin.
Mclairs83
Switched to gomo last month. Extremely regret. Keep having disconnection from 4G data despite having full strength and under hot sun.
Was on giga previously. Luckily no contract. Going to jump back to giga.
Hardware138
Recently gomo internet access is patchy.. out of sudden very slow. Anyone else experiencing that ?? Thinking of porting out to others to try.
Whats a better alternative?
Passer
does anyone know if gomo have any minimum staying period? first month can port out already?
maumu
Wah got databank sia. Does it apply to the 10gb plan?
yes, I'm on 10gb plan and I could bank in 5gb (as long as you have >5gb balance).
Btw, is the donating data function missing in the app?
can't find it
Sent from A universe Where pink PWNED everything
yeah it's gone... was trying to donate 5gb and found the 'bank' instead.
the bank feature seems to be like a pledge thingy. say you have 8gb and you bank in 5gb (minimum), the balance still shows 8gb (and not 3gb). but the base plan is reduced by 5gb. so you won't know when your base is emptied and they automatically activate the bank's 5gb (?).
would rather see 3gb so that I can monitor my usage and not having to use the bank's 'reserve'. I suspect once activated, it's 5gb deducted each time? 🤷‍♂️ need others to test it out...
kelvinti
Can the banked data be used as Roaming data in those supported countries? 🤫
edmwing
The data bank is only useful if you have "gift data" which is accessed after you depleted your "base data" which can be difficult if your base data is big and the gift goes wasted after expiry. So the order of usage is base -> gift -> bank.
crystalnox
They could have just simply implemented long expiry rollover instead of this complicated sh*t that only benefits them when consumers forget to bank.
Kiwi8
Deluxe Member
Actually for this banking feature, for the start of the data cycle just bank all in right, since if base data is used up will start using from the bank rite?
Arandalo
What are the perks available for redemption?
Customers with sufficient data bank balance can convert it to redeem a 3-day Unlimited Talktime pack and/or 1-day Unlimited Data Roaming pack to Malaysia, Indonesia or Thailand. Stay tuned for more perks coming your way!
https://gomo.sg/databank
kelvinti
1 day unlimited roaming data is also not very attractive and practical enough.
At least 3 or 5days lah.
A lot of restrictions..
