Please log in and verify your age to view this post. Why?
lian li q58Anybody know of any low profile ITX casing that is NR200 layout ( itx & sfx psu on the same plane )
Like the layout in below pic but slimmer ( < 125 mm width ; i intend to use low profile gpu )
170mm widelian li q58
24inchHi there, is 24 inch or 27 inch display more suitable for 1080P? I am looking to upgrade my 60hz monitor. Will I be sacrificing picture quality if I opt for 27 inch?
Thanks! Yes I sit very close to it due to my short sightedness and picture quality is essential. Think that 24 inch is better and cheaper too.24inch
27 FHD, picture quality not very sharp, especially for monitor where you sit very close to it...for 27, at least QHD
u can look at the ryzen 7 7700 + msi b650i edge @ $773 (758 + 15 for bundle only) from dynacore and adata xpg lancer rgb 2x 16gb 6000c30 @ $172 from tradepac.Hi, can someone recommend me a itx combo of CPU, MB and ram around $1000 to pair with 4070ti.
24". u start seeing 1440p monitors at 27".Hi there, is 24 inch or 27 inch display more suitable for 1080P? I am looking to upgrade my 60hz monitor.
there is a loss in dpi, but whether u can feel it is another story.Will I be sacrificing picture quality if I opt for 27 inch?
quite hard to find, tried searching on taobao but the closest i could find was with 1u rather than sfx psu.Anybody know of any low profile ITX casing that is NR200 layout ( itx & sfx psu on the same plane )
Like the layout in below pic but slimmer ( < 125 mm width ; i intend to use low profile gpu without riser )
Basically like a low profile NR200
Same with my search, most require flex psu but I would prefer to go with a more standard sfx psuquite hard to find, tried searching on taobao but the closest i could find was with 1u rather than sfx psu.
most cases with sfx psu is sandwich style.
i'm not into SFF builds but i do have a friend that love doing this.hi all, hoping to get some suggestions on new mobo to get (prefer Mobo that support DDR4 rams)
im currently using asrock b550m /ac with fractal design north case. With the nzxt kraken elite installed at the top, i was unable to install the vengence pro RBG rams even with the SL version.
can anyone recommend me a new mobo where the rams sit lower so i have more ram clearance space? my CPU is ryzen 5600. FYI using xpg rams and its fits just nicely only - the rgb are horrible (they look nicer in pics than they really are)
https://www.aftershockpc.com/products/amd-unbeatable-6700xt2Hi, looking for a new budget pc <1k to replace my 10 years old pc (i5 4670k with gtx970)
Playing games like dota, league, valorant, cs2, ark survival...
Should i diy or go for prebuild pc?
Due to medical conditions, eveything has to be online, cant go down to sls.
My diy would start from r5 5600(or should i go higher?), and for the rest pls guide me. Ty
ur pc sounds like overheating or psu problem.looking for some advice for replacing or upgrading my machine because it has started to shut down after entering games, or sometimes when watching youtube videos. sometimes I get the power cutoff kind of shut down (goes to black), and sometimes I get the video_TDR_failure nvlddmkm.sys error. Tried troubleshooting to no avail. I tried games like Dredge and it shut down my PC not even 1 min into loading the cinematic intro into the game, or crash in the middle of AOE2DE.
My current system was gotten from Aftershock in 2018 June.
Chassis: H500I
CPU: i5-8400
Mobo: ASROCK B360 PRO4
Graphics: Zotac GTX 1070ti
Cooling: Aftershock Glacier 240 closed loop watercooling
RAM: 16GB x2 DDR4 2666Mhz
SSD: 250GB Samsung 860 EVO M.2
HHD: 2x Toshiba 1TB
Chassis Fan: Default
I want to upgrade to something that can comfortably game 1440p on ultra settings.
Was looking into 4070ti paired with AMD Ryzen 5 7600 with a Gigabyte X670 Aorus Elite AX mobo.
But I'm not sure if I am going too much with this.
| ryzen 5 7500f + msi pro b650m-a wifi | 475 | pckaki |
| adata xpg lancer rgb 2x 16gb 6000c30 ddr5 | 172 | tradepac |
| thermalright phantom spirit 120 se | 51 | pc themes |
| wd black sn850x 1tb | 110 | viipc |
| gigabyte rx 7800 xt gaming oc | 784 | bizgram |
| adata xpg core reactor 750w | 125 | performance pc |
not sure if this will notify u, but maybe something u can consider is 3d printing ur own case? been thinking about designing my own case for a while as a fun little project.quite hard to find, tried searching on taobao but the closest i could find was with 1u rather than sfx psu.Anybody know of any low profile ITX casing that is NR200 layout ( itx & sfx psu on the same plane )
easiest would be to go for aftershock's 5600 + 6700xt for $900, really unbeatable price and will run ur games very well though u will have to deal with the low quality mobo, nvme and psu.Hi, looking for a new budget pc <1k to replace my 10 years old pc (i5 4670k with gtx970)
i dont think there will be much variation between mobos with regards to ram slot height since that is quite standard (like cpu height from pcb surface), maybe u should look for cases that mount the radiator further from the motherboard.im currently using asrock b550m /ac with fractal design north case. With the nzxt kraken elite installed at the top, i was unable to install the vengence pro RBG rams even with the SL version.
probably, neither of the games u mentioned look difficult to run, so u will be served just as well by a much cheaper 4070/7800xt imo though do ur research to see if those cards deliver adequate performance for ur other games as well. the x670 also feels overkill for a 7600, though if u like its features and aesthetic and fits in ur budget then by all means.I want to upgrade to something that can comfortably game 1440p on ultra settings.
