GPGT: Simba fibre broadband is here
Should I take it up?
  • Yes
    Votes: 81 57.0%
  • No
    Votes: 61 43.0%
  • Total voters
    142
guile
Can check if you see this in the network settings.
I don't have Simba. My area doesn't support it yet. Will prob wait when they do.
But my ethernet is a Realtek Gaming 2.5GbE Family controller.
Mancunian2
I on stuckhub fibre for 10 years liao
so far breakdown 5-6 times and 2 times not their fault
any reason to change?
pwongkk
Can consider getting both, which is what I am planning to do.
2nd one can be for link backup or if you are technical enough, can set up for load balancing or link redundancy.
I have a 4G mobile connection using a different telco for my current redundancy setup. Goodcto have another using a different media, if the fiber got cut by those contractors foing excavations or ISP doing maintence, your Internet is still functioning.
