I don't have Simba. My area doesn't support it yet. Will prob wait when they do.![]()
Can check if you see this in the network settings.
But my ethernet is a Realtek Gaming 2.5GbE Family controller.
All fibre ISP not use the same NLT infra mehDo they actually have their own cables infrastructure? Whose fibres are they actually using?![]()
via wired or wireless?Ok here are the first 2 speed test. I'll do more on the weekend. I'm working tomorrow so I need to get some sleep.
Simba The Lion King
All test wireless at the moment till I get my hands on 2.5G capable wired hardwarevia wired or wireless?
Need to pay for any ONT or setup fee? Thinking of jumping from M1 as the speed is only 500mbps
Read HWZ Forum Rules!
so what kind of self-installation is needed? if i IT newb dont know how to install how?Ok here are the first 2 speed test. I'll do more on the weekend. I'm working tomorrow so I need to get some sleep.
Simba The Lion King
Oh wow. I just renew 1Gbps plan on September and more ex. Tmd...https://whizcomms.com.sg/fibreplus-...CDqlg-qEcYZHrC3sUU4jcHqbhXz0A_KI4_o0w5ItV42aM
Whizcomm has entered the competition. But they provide ONR. Not sure if they can provide ONT with 2.5G WAN Port.
Can consider getting both, which is what I am planning to do.I on stuckhub fibre for 10 years liao
so far breakdown 5-6 times and 2 times not their fault
any reason to change?
FAQ says can use any router from previous provider, sounds like it’s ONT? and it’s aggregated 2.5..https://whizcomms.com.sg/fibreplus-...CDqlg-qEcYZHrC3sUU4jcHqbhXz0A_KI4_o0w5ItV42aM
Just plug in the cable only, and configure router. Very easy.so what kind of self-installation is needed? if i IT newb dont know how to install how?
ONR with all 4 1Gbps ports usable.FAQ says can use any router from previous provider, sounds like it’s ONT? and it’s aggregated 2.5..
Meaning your own routers only work as an AP.ONR with all 4 1Gbps ports usable.
Or a double NAT.Meaning your own routers only work as an AP.
