Which type of oil is the healthiest for cooking?
Travis_Touchdown
there ish label to state whether this cooking oil ish suitable for cooking or for salad etc... :s12::frown:
Igene
Tiagong extra virgin olive oil then suitable for high heat cooking.
Nefalrin
Vegetable oil is the least healthy
Eight of the most unhealthy vegetable oils include:
  1. Corn oil
  2. Canola (also called rapeseed oil)
  3. Cottonseed oil
  4. Soy oil
  5. Sunflower oil
  6. Safflower oil
  7. Grapeseed oil
  8. Rice bran oil
Nefalrin
Use Peanut oil. The best quality of all oil and healthy but not cheap.
Got Omega 6 and vitamin E
1982-1994
actually olive oil not suited for high heat.
for high heat coconut oil more stable.
Is it better to cook with virgin or extra virgin olive oil?
Typically, olive oil is a safer bet when cooking because of the higher smoke point and neutral flavor
So extra virgin olive oil is ok for frying food? Normal olive oil not ok?
I'm confused with Google results
Nefalrin
Use these oil to be safe ..
avocado oil, olive oil
Next should be peanut oil
Actually olive oil is not for high smoking point cooking. It is for low to medium cooking.
For frying chicken at medium heat is ok since frying chicken is done at medium heat
Not.banned.yet
Is it olive oil?
Cold pressed type is for salads is it?
Asking for my mum
Ya. Must see the cooking method, temperature and smoke point
this chart look good enough
Nefalrin
Not many food are fried at high smoke point.
Unless you spending the last minute frying chicken to get it's outer skin extra crispy.
1982-1994
OK so verdict is,
Olive oil is suitable for cooking/frying below 190°C
Extra virgin oil is suitable for frying above 200°C
