WiFi 7 routers (including WiFi 7 routers without 6GHz band support)
Hi Peeps
Do you think 2x BE65 or BE85 is enough for a 130sqm HDB?
It is difficult to predict WiFi coverage without details.
Please post the floor plan with details of the location of the Fibre TP, LAN ports in the rooms (if any), intended placement of the two nodes, as well as the ISP / plan (using ONR or ONT).
Chinese WiFi 7 router options (no 6GHz band, no 320MHz channel bandwidth, got MLO, 4096QAM, MRU, etc)
Huawei
Huawei BE3 Pro (1G port version): RMB399
Huawei BE3 Pro (2.5G port version): RMB499
Xiaomi
Xiaomi BE3600 (2.5G port): RMB 299 (just announced)
Xiaomi 6500 Pro (quad 2.5G ports, good for 2.5G plans): RMB699
Xiaomi 7000 (quad 2.5G ports, good match for 2.5G plans): RMB799
Xiaomi 10000 triband (dual 10G ports, maybe good for 10G plans): RMB1499
TP-Link:
https://www.tp-link.com.cn/product_cat_wifi7.html
TP-Link TL-7DR3610 BE3600, RMB 229
TP-Link TL-7DR3630 BE3600, RMB 249 (single 2.5G port)
TP-Link TL-7DR5130 BE5100, RMB 279 (single 2.5G port)
TP-Link TL-7DR6560 BE6500 (quad 2.5G ports, good match for 2.5G plans), RMB 559
TP-Link TL-7DR7280 BE7200 (quad 2.5G ports, good match for 2.5G plans), RMB 1699
TP-Link TL-7TR13090 BE13000 triband (dual 10G ports, maybe good for 10G plans), RMB 2199
ZTE
https://www.ztedevices.com/cn/product/中兴问天be7200pro路由器/
ZTE BE7200 Pro+ (中兴问天BE7200Pro+, dual 2.5G ports, good match for 2.5Gbps plans) RMB 599
H3C
https://www.h3c.com/cn/Products_And...lProducts/Star_Products/Home_Network/BE18000/
H3C BE18000 triband (one 10G port and three 1Gbps port) -- RMB 1799
Nokia has Nokia Beacon 24 WiFi 7 mesh solution, not so sure Starhub will bring it in or not. Or maybe they should bring in Nokia Beacon 10 WiFi 6E mesh solution first. As of now, Starhub only has the low end Nokia Beacon 2 to mesh with the 10G all-in-one ONR (WiFi AX6000).
https://www.nokia.com/networks/fixed-networks/home-wi-fi/
Singtel is the first local ISP to bundle WiFi 7 router with the 10Gbps plan (TP-Link HB810).
https://www.singtel.com/personal/products-services/broadband/singtel-symmetrical-broadband
Apparatus
Nokia Beacon 24 is a quad-band. If use here then it's likely a 2.4/5-1/5-2/6 rather than a 2.4/5/6-1/6-2 device
For Singtel 's TP-Link HB810 its wireless speed with MLO is only 10Gbps. The device is supposed to be 22Gbps wirelessly. So, did Singtel handicapped the MLO of the 6Ghz band?
No need to read too much from Singtel website.
It could be the MLO feature of the HB810 is not ready. Or it is simply Singtel's way of describing things.
In any case, as mentioned, real world WiFi 7 speed from the Wireless clients is still below 5Gbps now.
Apparatus
TP-LINK website also no say its HB810 MLO wireless speed is 10Gbps only. So why did Singtel site says so? In fact, Singtel is informing user upfront its MLO wireless speed is only 10Gbps hor.
MLO for HB810 not ready? Please lah. Ask TP-LINK whether its MLO for the HB810 is ready or not?
WiFi 7 wireless speed for real world speed test is below 5Gbps. Is this with MLO or no MLO? From what I read Windows 11 still not suporting MLO and that's why testing with 6GHz band is limited to 5Gbps
The following is what I believe since MLO is the main featured touted by the vendors.
The 5Gbps lab demo speed test from Qualcomm/Intel is already with MLO.
The 4.7Gbps lab speed test results from Huawei is also already with MLO.
TP-Link is still updating the FW for HB810 for Singtel usage.
https://www.singtel.com/personal/su...d-latest-firmware/TP-LINK-HB810-WIFI-7-Router
Microsoft is still preparing the better WiFi 7 support for Intel BE200 in Windows 11 24H2. So it will not be a supprise that MLO features of the TP-Link router still has some tuning to be done.
Apparatus
That Singtel link just show user how to update firmware just like you update your own router firmware
Yes, even Xiaomi WiFi 7 router with MLO also limited to 5Gbps.
Main reason is Windows is still not fully supporting MLO. When Windows provides full support for MLO then speed will breakthrough the 5Gbps limit
Jun Jun
I want an affordable wifi7 router with 6ghz wifi. Have many smart home devices.any recommendations?
The answer will depend on your definition of "affordable". The availability in local market is very limited as of now, mainly from TP-Link.
Firstly, if you subscribe to Singtel 10Gbps, then TP-Link HB810 (BE22000 rated) is free as part of the subscription. They also offer the seond unit at a discount price of S$16.80 per month (S$403.2 in total).
https://forums.hardwarezone.com.sg/threads/singtel-10gbps-enhanced-wifi-7.6983542/
I believe HB810 is now only exclusive to Singtel but I can see people started to list the unit in Carousell and asking for about S$600. The price should go down soon to something around S$500 if more people subscribe to Singtel 10Gbps plan. Take note it is using EasyMesh and not compatible with existing TP-Link Deco.
Note:
As of now in Jan 2024, I do not recommend buying any local version of WiFi 7 routers due to high price.
For local version of WiFI 7 routers in the open market, cheapest single WiFi 7 router is probably TP-Link Archer BE550 (BE9300 rated) at around S$499. Dual pack is TP-Link Deco BE65 (BE11000 rated) at around S$899.
Reference price from Challenger:
https://www.challenger.sg/tp-link-wifi7
Deco BE85 (BE22000) --> dual pack at S$1199
Deco BE65 (BE11000) --> dual pack at S$899, triple pack at S$1399
Archer BE800 (BE19000) --> S$799
Apparatus
Note:
Can get from Shopee for the TP-LINK Deco BE85 at $1199 for dual units as well
https://shopee.sg/TP-LINK-DECO-BE85...3a&xptdk=ae7f64b6-881c-4e12-b6bc-eb12471ca53a
Jun Jun
Wah.... so ex now.... might wait for abit more when wifi 7 becomes more main stream... i have s23.and 24 ultra so there are wifi 7 devices at home.
alex22
Tmall China
TP-LINK MSRP
RMB 229, BE3600
RMB 559, BE6500
RMB 1699, BE7200
RMB 2199, BE13000
If want mesh can mix and match, host at 1699 then clients at 229 each.
One pair of this would be ard sgd 390
TanKianW
Interestingly MyRepublic starts to bundle TP-Link Archer BE805 WiFi 7 router (BE19000, triband) to their 10Gbps Gamer Plan (normal 10Gbps plan is still bundling the Arche AXE300 WiFi 6E router).
It is not listed in TP-Link Singapore website yet, so maybe this is exclusive to MR now.
Spec from TP-Link US.
https://www.tp-link.com/us/home-networking/wifi-router/archer-be805/#specifications
Thank God, I sold my AXE3000 before this is announced. If not, will kana low balled jialak jialak! :LOL:
