Old $88.77 plan is cheaper and user can save $.
It still depends on your needs.
If no need so many contents, the new normal 10Gbps plan at S$69.95 is the best plan to go. It has the XGS-PON ONT + TP-Link EB810v router.
https://www.starhub.com/personal/broadband.html
For Homehub+ Ultraspeed bundle, indeed the older plan was cheaper at S$88.77. However, you got the Nokia all-in-one ONR with the older plan and power users may not like the ONR. For the new plan, you can also get a second unit of EB810v at S$15 x 24 = S$360 to form a 10G capable mesh. So it still depends on what you want.
https://www.starhub.com/personal/bundles/homehub-plus/ultraspeed.html
DarwinN9
Its seem like the earliest one can get setup with Starhub is in May 2024. By then EPL would have ended..
Apparatus
Is it? Did you do it online?
Lol.. That was what an agent told me.. so i was like half sian.. Sign 24 just to waste first 3 month..
Just go to SH outlet to sign up and there you can get the earliest date available
Unless business suddenly becomes so good......
I just signed up as a new user recently at SH outlet and 1 week later all settled
ElZedHaitch
Yes online.. The online dates were far earlier than the shop dates. I did it online while sitting beside the sales guy lol
DarwinN9
was there any special reason to go physical shop? Like discount etc?
Henry Ng
lol.. you existing user?
Yes existing user. May be you can call in early in the morning when they open to ask for earlier date. You can try to watch on your TV. That time after i signed up, i checked my Starhub App to see what i have for TV and can see that all the TV+ passes already there.
SkyShroud
What 10g switch are people buying BTW?
And what is the way to go? Ont to switch to AP?
ONT is not router aka ONR. You need something to do DHCP on.
ONT > Router > Switch
10 Gbps switch not cheap, just find one that fit your needs.
That's what I thought... But then the router has to stay in the db box I guess.
Put the main router in the DB Box is one option.
If you have two LAN ports next to each other in the living room you can relocate the main wireless router to the living room and put the switch in the DB box.
ONT in DB box -- living room LAN port 1 -- main router in living room -- living room LAN port 2 -- 10G switch in DB box -- LAN ports in other rooms
If you do not have two LAN ports next to each other (new HDB BTO may have two LAN ports in the living room but a bit far away) , you may consider pulling one cable from the second port to the first port as well.
williamyiyi
Hi, I tried to spam the superAdmin, but it shows this hint: WF UTURN.
Does anyone know that? I try to use a Wi-Fi password and make uturn, but also cannot.
I used ONR, called the required superadmin, and requested a change to ONT, which was rejected. :(
I would appreciate it if anyone knew how to pattern super admin passwords work. Thank you
Unfortunately you are out of luck -- as of now, the only chance to get the SuperAdmin password for the Starhub issued all-in-one Nokia XGS-PON ONR is to get the password from the installer during the instllation time.
Nobody has figured out how to do it in other ways.
1) To try to guess the superadmin password -- looks like no pattern one
2) Using an XGS-PON ONU to replace the Nokia ONR (theoretically possible but no one has done that).
Sorry to ask, but is the super admin password the same for all users? I try to call in to ask, CS says they don't have :)
Can anyone share the super admin with me? I appreciate any help you can provide.
It's unique to every ONR. If you didn't catch it during the initial ONR setup by the ISP tech, then you're probably **** outta luck.
williamyiyi
Thank you bro, really got the rash purchase the ONU. But worry, it's not working after that. lppl
williamyiyi
But bro, may I ask, we need to copy all the settings from ONR to this ONU, right?
