tiger2013
- Jul 25, 2013
I think it really depends on company. For bigger companies with the budget set in place, they will likely pay what they said, i.e. $8k to $10k.Say you saw a job adv for 8k-10k/mth salary.
After interviewed you matched like 80% of the JD and what the hiring manager is looking for, but your current salary is much lower.
You told the recruiter your expected salary is 8k, then the company ask for your current salary, cause they will verify once you are onboard.
The recruiter got back and informed that this company got a policy that max increment only 15% so it’s hard to match expected salary?
Isn’t internal policies use for salary increment only? Also apply to new hire? This role also requires you to guide and manage new joiner, so the responsibility is higher. Is the HR trying to pay low ball since the budget already set till 10k by management? Anyone encountered such scenario before?
But for companies with a flexible budget, they might not offer what they say. If they come back with that, then normally what I do is to probe about their training and what expensive courses you can take with the money saved from your salary. If you like their training programme and stats on expensive courses that people have taken, then it could be a good compromise. Otherwise, depending on how far off the offer is vs the budget, you can choose to reject them.
