- Sep 16, 2018
So what's the point in having IDS/IPS? Who wants to buy a router and to disable IDS/IPS?
It depends on the usefulness of the type of IDS/IPS offered by the router, most of the consumers do not need IDS/IPS. It is better to disable IDS/IPS anyway if you use UDM Pro or UDM SE with 10Gbps plan.
BTW, I turn off Asus AIprotection Pro feature on my Asus RT-AX86U as well, it is useless to me. I turned it on for a few times and it detected nothing. I find Adguard Home or Pi-hole to be more useful.
FYI Asus AIprotection Pro also claims to support IDS/IPS but it is not really true IDS/IPS and bascially useless.
https://www.asus.com/sg/content/aiprotection/
