Hi
I have gave a lot of thought and done a lot of read up on the subject. Just want to plan for the future
Few things to note
1) I have already completed my trunking running of the RJ45 LAN cables for my whole house. To upgrade the RJ45 LAN cables as much as possible to fiber optics first
2) 25/40G transceivers and devices can come later when 25/40G broadband is available and the prices of the transceivers/devices go down
3) To upgrade current TP LINK eb810v router to 3x TP LINK BE85 nodes
4) To buy the following SFP+ switches
- QNAP QSW-3216R-8S8T (unmanaged switch)
- 2x QNAP QSW-M804-4C (managed switch used as unmanged switch)
- MIKROTIK CRS305-1G-4S+IN (managed switch used as unmanged switch)
5) Solo10G SFP+ adapter (fanless)/QNAP QNA-T310G1S SFP+ 10G ethernet adapter (fanless)
6) Very important is this upgrade is for my single-storey HDB unit only so transmission distance is not a factor of consideration. FI, my longest RJ45 LAN cable is about 30m
Since TP LINK BE85 mesh node does NOT support VLAN so managed switches will be used as unmanaged. Bascially, I just need the SFP+ ports.
Fiber Optics Cables
AMPCOM OM4 LC to LC UPC 50/125 Duplex Multimode LSZH 2.0mm Fiber Optic Patch Cable 40Gbps
https://shopee.sg/AMPCOM-OM4-LC-to-...41&xptdk=7456599f-772b-47a8-82be-ae656324db41
ATZ LC Multimode Fiber Optic Patch Cord Duplex (OM4) 40Gbps
https://shopee.sg/ATZ-LC-Multimode-...26&xptdk=2d40eb38-dca5-416e-9add-34a797eaa626
10/25/40G Tranceivers
10Gtek 10GBase-SR SFP+ Transceiver, 10G 850nm MMF, up to 300m (about $24 for 2 pcs)
https://shopee.sg/10Gtek-10GBase-SR...4c&xptdk=4fc6c04b-ac42-471b-9e4d-42088e57f24c
10Gtek 25G SFP28 SFP+ Transceiver, 25GBase-SR Module, 850nm MMF, up to 100m (about $24 per pc)
https://shopee.sg/25G-SFP28-SFP-Tra...69&xptdk=76423809-575c-4495-8b9e-b05ffea9e169
CISCO QSFP-40G-SR-BD duplex MMF with LC connector (preferred since existing cables are duplex MMF)
CISCO QSFP-40G-SR4 with MTP cable and connector
Anyone like to comment with this upgrade to 10G fiber optics? If you have cheaper alternatives for the 10G SFP+ switches/transceivers please recommend. Just make sure the transceivers are compatible to brands like QNAP, TP-LINK, MIKROTIK, SONNETTECH etc. If possible, I would prefer to use one brand of transceivers.
Note :- I would not recommend the use of 25G transceivers in 10G devices here although it's possible as posted in another thread, post #33
https://forums.hardwarezone.com.sg/...d-usb4-tb4-devices-for-10g-use.7011800/page-2
Thanks
Few things to note
Fiber Optics Cables
Thanks
