- Sep 16, 2018
Another thing is, is it recommended to use MLO?
I have it disabled for now as I cannot use it if I am only using the 5ghz-1 which is the 5.2ghz band.
What kind of WiFi 7 clients you are using now?
I do not have any WiFi 7 clients now so I disable MLO.
Intel BE200 based WiFi 7 adapter is said to be not supporting 5GHz-1 and 5GHz-2 MLO, even if you configure your Xiaomi BE7000 as a triband router.
It does support 2.4GHz + 5GHz MLO, which may not be so useful in the end. Some tests show it can help on the speed and latency on the far range as 2.4GHz starts to be useful at far range.
It is perfectly okay to disable MLO as of now since Windows 11 does not really have good MLO support now, you have to wait for the formal release of Windows 11 24H2.
