解签 - Decipher of Divination lots from Temples
ZhouXingXing
Hi all,
This thread is for sharing and interpreting temple lots (解签) you may have drawn from places such as Bugis Temple, Guang Min Shan, or other temples in Singapore.
We will help to interpret the following systems: 观音100灵签, 60甲子签, and 雷雨诗100灵签.
Drawing lots or using sheng beis (two red wooden blocks) is not about predicting the future. It is a way to seek guidance when you feel lost or at a crossroads, unsure of which path to take.
Before asking Guanyin or the temple deity for advice, it is important to be clear about your question. Do not approach without an idea or plan in mind. For example, you might ask which job or field suits you, or whether you should leave your current job.
So which tools to use? Lots or Sheng beis (2 red wooden blocks)?
a. To use Sheng beis aka 2 red wooden blocks when:
The questions that you are asking belongs to yes, no, can, cannot or whether option 1, 2,3 is better = Use sheng bei to ask no need draw lots.
b. To draw lots when:
Your questions cant be answered using sheng beis like a. above.
Example: If advice what should i take note, what should i do, whats the advice for me if i wish..
1) For the SOP to draw lots, you can read up HERE
2) For the SOP to use 2 red wooden blocks to ask questions aka phua bei or sheng bei, you can read up HERE
3) For sample/example of asking about relationship related questions, you can read up HERE
4) For sample/example of asking about career related questions, you can read up HERE
5) For myth and "hear say" about drawing lots, you can read up HERE
When you gotten the lots from the temple, you can post your questions asked and the lot received in this thread, either me or @mgx-alander will decipher for you.
Apologies and thank you for your patience if I don’t reply the same day. I work full-time and also provide 紫微斗术 consultations, so replies may be delayed.
Please note: if the wrong method is used to ask a question, we will first advise you to read the guide in this post or thread.
We reserve the right not to assist with lot interpretation when the wrong method is used, as it will lead to inaccurate advice.
When posting, please provide the full context of your question to GYM. We cannot guess or “read minds.” Avoid giving only part of the story—be clear about what you asked GYM in detail.
We will not entertain questions that treat GYM like a fortune teller, such as asking “Will I get the job?” or similar predictive questions. Please note that this thread is for guidance, not fortune telling.
Please note that we will not interpret lots or questions that involve third parties, including siblings, unless it is an exceptional case.
Feel free to use above info but beware of karma if one claims its his/her work without my acknowledge.
ZhouXingXing
Steps for drawings lots (Full SOP).
a. Light incenses and stand infront of Gym or the God of the temple (not facing 天公) , intro yourself, your purpose of visit and your questions.
Report your Name, DOB with Time (Use 农历 lunar calendar if possible) and would like to ask a question pertaining to XYZ
b. After putting the incenses into the temple urn, proceed to one side of temple and wait for about 15-20 mins (This allows GYM or the God of the temple to check on your issues) - Many tend to skip this part which is not advisable.
c. Take lot tin and sheng beis and proceed to the prayer section (if any).
d. Repeat your question again and ask GYM/God if he is ok to give you advice on your question(s) via lot?
- If yes, please give you 1 or 3 sheng beis (you decide but most important is to mention give you 1 sheng bei if you intend to use 1 sheng bei method)
- If there is no sheng bei mean your question, Gym or the God of the temple do not wish to advice which could be due to Various reasons or factors (will share in subsequent posts)
- if got sheng bei, proceed to e.
e. Take the tin and start shaking.
f. when one lot came out, ask GYM/God if this is the lot he want give you if yes, give you 1 sheng bei.
- if got sheng bei = yes, go to step i. below
- if no sheng bei, go to g.
g. put the rejected lot one side and continue to draw lots.
h. when another lot came out, repeat step f. again.
i. Ask GYM/God if there would a 2nd lot for your question?
- if yes, give you 1 sheng bei and you throw.
- If no sheng bei mean GYM/God only wish to give you 1 lot as advice.
- If got sheng bei, it means GYM/God want to give you more than 1 lot so you proceed to next step J
j. Put the confirmed lot one side and put the rejected lots back into the tin and restart the draw lots steps again.
Repeat step f, g, h until you get no sheng bei when you ask GYM/God if there is next lots?
k. note down the sequence of the lot and just let us know will do. we will interpret for you like lot 3, lot 17 then lot 45.
Some may ask why need to do so complex steps, one lot is enough as GYM or the God of the temple 神通广大 one lot is enough. yes right GYM or the God of the temple is but we are not.
When GYM of the God has multiple advice for you, he will give you more than 1 lot and its like a jigsaw puzzle. Gym or the God can give up to as many as 10 lots for one advice. If one did not check if there is next lots and just left with 1 lot, we are not sure if the advice is complete and hence, unable to interpret correctly. or give you half interpretation then you come and say not accurate
(Its like calling someone and hanging up the call halfway )
This would result in the person interpreting the lot incorrectly and resulted in the person taking the wrong actions due to the person interpreting the lot would have to bear some of the karmic actions too. This includes using the wrong method to ask question like drawing lots asking yes no or optional questions too. The chance of lots answering such questions is low.
ZhouXingXing
Steps for using sheng beis (2 red wooden blocks) to ask questions 。
b. After putting the incenses into the temple urn, proceed to one side of temple and wait for about 15-20 mins (This allows GYM or the God of the temple to check on your issues). Meanwhile, you can think through your questions - Many tend to skip this part which is not advisable.
d. Inform GYM/God of your question.
Example it is a question of which options (A or B) to choose is better for you.
e. If option A is better for you, please give me 1 or 3 sheng beis and you start throwing the sheng beis.
f. Regardless of the results, you take the sheng beis and proceed to ask if option B is better for you.
g. After 2 throwing the sheng beis for 2 options, if option A has sheng bei and option B does not have, it means Option A is better for you.
In event, both options have same results as both sheng beis or no sheng beis. Proceed to draw lots by following the draw lots SOP to see what GYM/God wish to tell you about your questions (usually got hidden issues that you are not aware of)
h. Note down the lots received and let us know the results of asking questions using sheng bei method and the lots received so we can decipher for you.
Example:
Ask about option A and B, both got no sheng bei and draw lot received lot 2 and lot 98.
How to use the sheng beis aka 2 red wooden blocks?
As per the picture above.
For using 3 sheng beis as yes, you have to achieve 3 continuous sheng beis for the 3 throws at first attempt.
Meaning, first throw = sheng bei, 2nd throw = sheng bei and 3rd throw = sheng bei.
If you wish to use 1 sheng bei as yes, you have to upfront say like example: if this is the lot for me please give me 1 sheng bei.
In event when you get a xiao bei at first throw, you can retry again and also rephrase your question to be more direct and clear so Gym or the God can understand what you trying to say.
If you tried 3 times and get all xiao bei, it mean they do not wish to answer your question. You can try asking again like in 1-2 weeks later. (This is for asking questions, not meant for verify if the lot is the one that Gym or deity wish to give you)
ZhouXingXing
Asking about relationship related questions:
For single, hoping to meet someone. There are 2 type of questions that one can ask.
1. When will the 有缘人 appear?
for 1. can use sheng bei to ask.
a. Ask GYM or God of the temple when it will appear.
b. If it will appear between June to Dec 2024, please give you 1 sheng bei.
- if you gotten 1 sheng bei or no sheng bei, proceed to to c.
c. if it will appear between Jan to June 2025, please give you 1 sheng bei.
- if you gotten 1 sheng bei or no sheng bei, proceed to to d.
d. if it will appear between july to Dec 2025, please give you 1 sheng bei.
- if you gotten 1 sheng bei or no sheng bei, proceed to to e.
e. if it will appear between Jan 2026 to June 2026, please give you 1 sheng bei.
By now you should have the answer. if you gotten a sheng bei for the period asked like between Jan to June 2025 and no sheng bei for the other period you asked, it mean you got very high chance of meeting the person between Jan to June 2025.
You could also received answers of meeting someone in 2 periods too. So during that period, you need to increase your social activities like meeting more people like new friends or old friends that you did not contact for sometime. Please do not do nothing and expect the 有缘人to come find you, chances of it appearing out of no where is low.
in event, all the periods (usually we asked for 2 years) do not have sheng bei, you have to ask GYM or the Temple god to advice what went wrong or something that you need take note of change ? as within 2 years for sure, there will be some 缘分 appearing. So you take the lot tin and start drawing lots (Follow draw lots SOP).
For attached couple, from my experiences, usually people like to ask the following:
i. if he or she is the one i will married or settle down with (正缘)?
ii. What to do to improve the relationship (usually couple met with issues)
i. If you have been together with your bf/gf for more than 6 months or 1 year, usually wont advise to ask such question because both already put in effort into the relationship and if want to end the relationship due to this, it would be hard for his/her partner to swallow if nothing bad has happened between both of you (like relationship is stable etc)
One can ask GYM or the temple god, if the person is my 正缘。
- Follow the ask question using sheng bei SOP
- Inform GYM or god that currently you are in a relationship with so and so (Say the partner name and DOB)
- Ask if so and so (your partner) is your 正缘? if yes give you 1 sheng bei.
So what if you are not suitable to ask if your partner is your 正缘? (Together for quite sometime like more than 1 year kind).
if both have the intention to move to next stage like getting married. One can ask GYM or the temple God, in current relationship, what to take note or have to change to ensure the relationship would be ok/smooth esp after marriage.
This question have to draw lot so need to follow the draw lot SOP.
For married couples, the most common questions received was:
- Should i divorce with my wife or husband?
For such question, usually GYM or temple God likely wont answer you directly (Unless special circumstances which is very rare).
One has to decide if you want to save the marriage or dont want to save the marriage ?
If one do not want to save the marriage, can no need to ask at all.
If one wish to save the marriage, can ask for advice on how to go about saving it via drawing lots.
For such question, if you need more info do feel free to DM me.
ZhouXingXing
Asking Career/work related questions.
What can be ask?
- Received job offers but not sure if to accept
- Which job is better for you in terms of progression
- Asking advices pertaining to job (not choices or option type of question)
Not advisable to ask:
- Will i get the job after attending interview?
- Should i quit my job?
- Asking about or for someone else.
- Unethical questions
Esp for those asking if GYM or God if they would get the job after they attended the job interview. GYM or the God is not the one hiring you, please be patient and wait for the results, if not is call up the company HR to enquire about the status !
1. Not sure if should resign from current job?
a. No need to draw lots or use sheng bei to ask
b. Just proceed to look for new jobs.
c. When received offer, can ask if the job offer is good for you in terms or career progression / welfare etc (depends on your goal) by following the Steps using Sheng bei method. If got sheng bei mean job is ok to take.
2. Not sure which field or job is suitable for you?
a. First sit down and think thru what jobs that you may have interest in, lets say 3 jobs you are interested in but not sure which to apply.
b. Follow the Steps using Sheng bei method and to let Gym or god of the temple know choice 1 is xx, choice 2 is yy and choice 3 is zz.
c. Follow the steps and ask all the choice one by one using sheng bei.
d. if choice zz and yy do not have sheng bei but choice xx got sheng bei, it mean xx is more suitable for you.
e. if 2 choices got sheng beis, it mean both choices suits you and you can decide which one to take.
3. Seeking advices related to your work (not yes no type or option type of question), can draw lots (Follow draw lots SOP)
Do feel free to ask if you are not sure how to formulate your question correctly :)
Will update if i realised i missed out any points again
ZhouXingXing
FAQ:
1. who am i?
ans) I'm just someone with a day job, helping out to 解籤 when i'm free but moving forward, i would be doing more of zwds stuff but will still be around to help out here.
2. When i started learning and practicing 解籤 and who is my "customers" ?
ans) Since 2015 and my "customers" were mainly from Taiwan as i learn 解籤 from one Taiwan master.
Below is the famous 解籤達人 from Taiwan and the video below accurately demonstrates the purposes of using sheng bei and lots. furthermore, he also explained the outcome aka karma of those smart alex (watch the video till end)
Wrong method used to draw lots = wrong advice = wrong direction taken = So whose fault ? 神明和解签人的错?
ZhouXingXing
Myth and "Hear Say" for drawing lots
1) Can ask few question at one go?
Ans) Not correct
Only 1 question per time because you wont know the lot given is not mean for which questions you asked (example you asked 3 questions together, you wont know the lot is answering for which questions)
2) To stop drawing lots when there is 3 consecutive no sheng bei for the lots that came out of the tin and ask another day as it is not a good day to ask about your question.
Ans) Not correct.
If you have asked GYM or the deity if they are ok to give you lots to advice for your abc issue and gotten a sheng bei, you should not stop at 3 tries, meaning 3 lots came out but all no sheng bei. Why?
GYM or the deity already said ok to give you lots but why do you think GYM or the deity do not wish to give you lot or think shall return at another day to ask again when you did not get a sheng bei after 3 lots came out of the tin?
If GYM or the deity said ok to give you lots mean they will give you the lot (They wont lie to you), just that it may take abit of time for the lot that they want give you to "shuffle" through your shaking to come out. All these need time and it may take awhile to come up so be patient and dont be gan chiong !
3) Dont keep asking the same questions within short period of time
Ans) Yes, its true.
When you gotten the answer from GYM or deity using sheng bei or drawing of lots, one should avoid asking the same question again within a short period apart. like asking about question A on week 1 and return to ask for the same question on week 2 or end of week 1.
So whats the sign that GYM or deity would give when one keep asking about the same question all the time ?
High likely the person would get xiao bei all the time or getting the lot keep saying the say results over and over again.
4) Drawing of lots need to take note of weather and time of the day as it would affect the results.
Ans) Not true.
One need to know the purpose of the lots given by GYM or deity. Lots and sheng bei is the tool that we use to communicate with them.
when their reply or response is too long, they will give you lots and the lots would present the message that they wish to tell you. So regardless of sunny or rainy weather, when GYM or the deity wish to tell you dont worry, the message of dont worry will not change even its raining or sunny.
5) Interpretation of lots need take note of time, place, the person dob and zodiac animal to be accurate?
Ans) Not true.
We are not doing fortune telling, as mentioned in the point 4 explanation, lot's meaning contains the message of what GYM or the deity wish to tell you. The person who interpret the lots need to know the techniques in order to get the message out of the lots.
For example: Its like the lot is saying "u evol i" the person who know how to interpret will get the message " i love you" out of the lot.
As we cant talk or communicate with GYM or deity directly that is why they will give us lot as a form of message to us. Its simple but often it was being complicated.
6) 解签人会通灵?
Ans) No
Sorry we dont know how to 通灵 so what you said to GYM or deity and gotten the lots or sheng bei results, has to tell us in details without missing out any info. otherwise, we cannot see the full picture and interpret your lots and sheng bei results correctly and gave you the wrong interpretation instead.
ZhouXingXing
Credibility and reliability of our method in asking, drawing lots and interpreting.
Definitely, i had came across many asking or commenting that the methods i shared were rubbish, nonsenses or not practical just because it is very different from their knowledge or instructions/method given from the temple.
However, i would like to share that the methods i use, came from Taiwan and below i will share some of many positive feedbacks given by the "customers"
1. About relationship related questions - Click here to view
2. Life direction, Finance etc. - Click here to view
3. Job related - Click here to view
4. Asking question using Sheng bei aka Phua bei - Click here to view
5. About relationship related questions Part II - Click here to view
6. Finance related questions - Click here to view
7. About relationship related questions Part III - Click here to view
Shion
Senior Mentor
If get 阴杯 can no need ask further or shake or throw.
If answer is a definite no, it is a sure no. I throw before 7 x 阴杯 consecutively.
Likewise, if got answer or answer is a definite yes, throw many many times also will be 圣杯. I throw before 5 x 圣杯 consecutively before too.
My humble opinion and experience.
jack-320
Hope it do not get merged for some reason
Please also note that some (if not all) lot tin at bugis does not have exactly 100 lots
some have duplicate numbers, some have missing lot numbers
Not possible to get 2 lot tins and sort out, security guard will stop you
so you will have to take the lot tin as it is
ZhouXingXing
i heard lot 99 was purposely removed for some reasons but not sure its for all or some tin nia
ZhouXingXing
Hi Shifu,
I went to GYM temple to seek advice on my career. I ran into some uncertainty in my new job and face risk of losing my job.
Long story short, I started sending cv for few weeks already, but nothing materialized. I’m getting worried as I may be jobless soon. I follow the SOP in page1 and my first question was whether I can find a job in the next 3 months (Jul-Sept), and I threw and got sheng bei. Then I proceed to ask for further advice, with GYM permission(I got sheng bei). I got 3 lots in the order of 66, 64, 61.
A quick check showed all lots are medium-bad. It’s quite worrying because I thought I had high chance of getting a job in next 3 months? Appreciate Shifu help to explain GYM advice. Thank you
Read HWZ Forum Rules!
Hi
For the lots you gotten, the advice is to inform you that your situation at work is not optimistic as what has been done cannot be reverse and going forward, things at work wont be that smooth if you are still at the job.
You can just keep sending resumes, be active in looking for new opportunities. meanwhile if you got time, you can drop by the temple to inform GYM to bless you and link you up with the company that you have the 缘分 with.
ZhouXingXing
Any idea what's the reason? What is lot 99 about?
Its the so called bad lot..
I hear say, not sure if its true not, many years back got someone with issue gotten this lot. the person went to one store or person (not sure if its outside the temple) . The person who interpreted the lot and told the person that its very bad, if do nothing will die or something (along this line), then recommend the person go somewhere else to do some ritual or something and kena cheated $$.
Will faint if draw this lot. Kong Meng San Monastery is using 妈祖签 if I am not wrong. Their lot is also super accurate.
Yup.. KMS is using 60甲子签, much more direct and easy to understand :)
Hi
Yes indeed. During the first month I joined this company I felt uneasy already and many things happened which lead me to believe my boss is waiting for time to kick me out.
My time is running out and I still can’t find a job. when I asked GYM whether I can find a job in the next 3 months, I get sheng bei. Does this means this 3 months my chances of getting jobs are higher.
Is there any advice regarding my job search per the 3 lots? Thanks
